Compression Test- what does it actually test?
Old Apr 25, 2007 | 07:21 AM
vinuneuro's Avatar
Default Compression Test- what does it actually test?
What part(s) of the engine does this really test? It only tests how well the valves are sealing and the compression of the..compression rings right? So in the case of oil consumption, it doesn't say anything about the oil control rings, valve seals, guides, etc- yes/no?
Old Apr 25, 2007 | 07:33 AM
117's Avatar
117
In my experience, no, a compression and/or leak down test will not tell you the condition of the oil control rings.
Old Apr 25, 2007 | 08:47 AM
mgags7's Avatar
A compression test certainly says nothing about valve seals at all.
Old Apr 25, 2007 | 10:00 AM
98vtec's Avatar
moderator emeritus
Default Re: (mgags7)
its simply testing a cylinders ability to hold compression. that is.....rings and valves.
Old Apr 25, 2007 | 10:13 AM
preludeguy_92's Avatar
Default Re: (98vtec)
Yeah and I had bad oil rings and was eating a ton of oil and still had great compression.
Type 56
Oct 12, 2016 11:10 AM
usdmblackcivic
Sep 4, 2010 11:56 PM
Cheez-It
Oct 2, 2007 07:27 PM
mafay2
Nov 11, 2004 07:34 PM
Soled Out
Sep 9, 2003 05:08 AM
