-H23 engine-
Old Apr 26, 2007 | 06:48 PM
shadow29485's Avatar
Default -H23 engine-
I here a lot of talk about the "H22 swap", as in engine replacement. What about, my H23A? What can anyone tell me about my engine.....In general?
Like what to pay attention to? Specifics of problems acquainted with the H23A, and so forth. I know the question isn't very specific, but I'm just woundering why the H22 holds such a value to you guys on the forum.
Thanks,
-Shadow-
Old Apr 26, 2007 | 07:16 PM
Hawkze_2.3's Avatar
Default Re: -H23 engine- (shadow29485)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow29485 &raquo;</TD></TR><TR><TD CLASS="quote"> I here a lot of talk about the "H22 swap", as in engine replacement. What about, my H23A? What can anyone tell me about my engine.....In general?
Thanks,
-Shadow- </TD></TR></TABLE>
Technically, the H23A is the VTEC engine from the Accord Euro R. Your Si engine is an H23A1 DOHC non-VTEC...there is definately a difference.
Your H23 is the same engine block and intake system as an H22, but it does not have the VTEC system and does not rev as high (safely ). It's basically an H22 without VTEC and it makes it's torque a bit sooner than an H22. You can easily get as much power from an H23 with a few mods.
I am keeping my H23 for sure...it's a good engine.
Old Apr 26, 2007 | 07:44 PM
BlownH23a
Guest
Posts: n/a
im making close to 250 hp on mine and its still breathin, i like it
Modified by BlownH23a at 4:49 PM 5/3/2007
Old Apr 26, 2007 | 07:45 PM
preludefien
Guest
Posts: n/a
Default Re: -H23 engine- (Hawkze_2.3)
alot of ppl sleave and boost..
Old Apr 27, 2007 | 02:41 PM
Thanks,
Now I get a better idea. Besides the a good tune up, intake, and exhaust, what other type of mods can be looked into, as to better performance for the H23A1.
Thanks again,
-Shadow-
Old Apr 27, 2007 | 04:17 PM
PirateMcFred's Avatar
Unless you boost, the 3 most important things you can do for that engine.
Header/exhaust
higher compression
camshafts
A little ingenuity and those three mods got me to 200whp and 183wtq after tuning.
Pirate
Old Apr 27, 2007 | 04:21 PM
98vtec's Avatar
moderator emeritus
Default Re: (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">
A little ingenuity and those three mods got me to 200whp and [B]183wtq[b] after tuning.
Pirate</TD></TR></TABLE>
i hate/envy you.
Old Apr 27, 2007 | 04:23 PM
Default Re: (98vtec)
Get Randy to make me a prototype header and we will see what else we can come up with... I got a slightly larger TB installed now too. Should help a little more.
If I were into drag racing without a filter I could try a nice big velocity stack too and see how that works open header.
Pirate
Old May 3, 2007 | 02:29 PM
After the headers and exhaust, How would you create higher compression?
Thanks...
Old May 3, 2007 | 02:37 PM
MooJenLude's Avatar
Internals. I'm in the same boat you are...Is it a good "all motor" engine? I don't wanna put out 1500 for an h22
Old May 3, 2007 | 03:45 PM
Cottonwoodz's Avatar
i would put out 1500 for a h22..... H23's are junk, unless boosted right (no corners cut) I would take a all motor h22, over a all motor h23 anyday.....
Old May 3, 2007 | 06:21 PM
esedulerp5tenin's Avatar
Default Re: (Cottonwoodz)
bOOOst teh 23
but i'm biased
Old May 3, 2007 | 06:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">i would put out 1500 for a h22..... H23's are junk, unless boosted right (no corners cut) I would take a all motor h22, over a all motor h23 anyday.....</TD></TR></TABLE>
That's a pretty narrow mind.
If I had an H23 and $1500 to blow I could make an H23 that would kick an H22 swap's ***. You're wrong on the H23 being junk.
Pirate
Old May 3, 2007 | 06:33 PM
SteveoBA8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">i would put out 1500 for a h22..... H23's are junk, unless boosted right (no corners cut) I would take a all motor h22, over a all motor h23 anyday.....</TD></TR></TABLE> Well good for you and your opinion. I wish my H22 had 183wtq
Old May 5, 2007 | 06:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> I would take a all motor h22, over a all motor h23 anyday..... </TD></TR></TABLE>
Old May 5, 2007 | 03:59 PM
Moron. But that's your right.
Old May 5, 2007 | 10:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I would take a all motor h22, over a all motor h23 anyday..... </TD></TR></TABLE>
Old May 6, 2007 | 07:03 AM
MooJenLude's Avatar
McFred 1 Cottonwoodz 0
Old May 6, 2007 | 07:32 AM
93PreludeF22's Avatar
Well I'm not trying to take over this post but it has helped me if I decide to get an h23. I currently have an f22 motor and I plan on getting a swap as soon as I can but I dont know which motor I should go with. To me they both seem like great motors. I do want to boost in the future so thats something im keeping in mind. What motor would you guys go with in yall's opinion knowing that its going to end up getting boosted? Sry Shadow if this takes over your post. Any opinions would help.
Old May 6, 2007 | 08:14 AM
rch022's Avatar
Default Re: (93PreludeF22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93PreludeF22 &raquo;</TD></TR><TR><TD CLASS="quote">Well I'm not trying to take over this post but it has helped me if I decide to get an h23. I currently have an f22 motor and I plan on getting a swap as soon as I can but I dont know which motor I should go with. To me they both seem like great motors. I do want to boost in the future so thats something im keeping in mind. What motor would you guys go with in yall's opinion knowing that its going to end up getting boosted? Sry Shadow if this takes over your post. Any opinions would help.</TD></TR></TABLE>
h23's are more commonly boosted, and i've heard its safer than to boost an h22.
Old May 6, 2007 | 12:09 PM
treddin's Avatar
Default Re: (rch022)
last i "heard"....compression on the h23 is better.....thus the boost ~ H22 has vtec "vtec" Turbo technology...doesn't allow for the greater "safer" boost.....correct me if i'm wrong...
Old May 6, 2007 | 04:33 PM
98vtec's Avatar
moderator emeritus
Default Re: (treddin)
where do you people come from?
go back to your shanties.
Old May 6, 2007 | 04:47 PM
jwyndsdime's Avatar
h23's are fun. sleeve it and boost it.
Old May 6, 2007 | 04:53 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">where do you people come from?
go back to your shanties.</TD></TR></TABLE>
yes he is talking to you cottonwoodz
Old May 6, 2007 | 05:11 PM
98vtec's Avatar
moderator emeritus
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
***.</TD></TR></TABLE>
applies to everyone who "heard" not "know"
