H22A. Problem with overheating.
Old Apr 26, 2007 | 10:49 AM
popesjdmh22lude's Avatar
Default H22A. Problem with overheating.
I have a 93 Honda Prelude with an h22 JDM motor.
Problem: Often over heats just idling. Going down the road its fine.
when sitting and idling for a period of time it starts to overheat, but then drive it and the temp goes down.
hmmm...? any suggestions?
Thanx,
Jared
Old Apr 26, 2007 | 11:10 AM
marks_lude's Avatar
you fan isnt turning on probably.
check the fan to see, then inspect the motor, fuses, etc.
or ur coolant is low.
Old Apr 26, 2007 | 11:13 AM
preludefien
Guest
Posts: n/a
Default Re: (marks_lude)
its going to get hotter at idle...if the fan comes on then its not overheating...its hot because it doesnt have cool air flowing through it...so my question is does your fan come on
Old Apr 26, 2007 | 11:27 AM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marks_lude &raquo;</TD></TR><TR><TD CLASS="quote">you fan isnt turning on probably.
or ur coolant is low.</TD></TR></TABLE>The fan has nothing to do with it. I have owned my car for 5 years and I have NEVER heard the fans come on. I've tracked my car several times (20 minute sessions) too.
If it is overheating at idle, I would guess there is air in the cooling system, the thermostat isn't opening all the way, or the coolant level is low. Those are the basics.
Old Apr 26, 2007 | 12:50 PM
mattsnooz's Avatar
Default Re: (AndyD)
never? the fan kicks on once and a while.. whenever your coolant temp reaches a preset level, than the fan kicks on to draw air into the grills of rad to cool fluid.
Old Apr 27, 2007 | 04:23 AM
marks_lude's Avatar
Default Re: (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">The fan has nothing to do with it. I have owned my car for 5 years and I have NEVER heard the fans come on. I've tracked my car several times (20 minute sessions) too.
If it is overheating at idle, I would guess there is air in the cooling system, the thermostat isn't opening all the way, or the coolant level is low. Those are the basics. </TD></TR></TABLE>
i hope ur not serious....
trackin ur car has nothing to do with it. since your moving fast, the air thru the radiator is goin way faster than any fan could pull, so it would indeed be pointless to have the fan running while tracking.
the fan is designed to pull air when the car is not moving (ie not pushing air thru the rad itself). sure the coolant could be low, and thats why i said that in my first post, but dont try and say the fan has nothing to do with it when thats the sole purpose of the fan. "TO KEEP THE ENGINE COOL WHEN THE CAR ISNT MOVING"
aznlaoboi315
Mar 13, 2008 02:35 PM
DCshoecompany
Sep 10, 2007 11:23 AM
92integraVTECgsr
Jul 23, 2005 03:11 PM
celica26
Dec 29, 2004 08:40 PM
wsiracerz
Jun 7, 2004 12:08 AM
