How do I remove this part
Old Apr 30, 2007 | 12:40 PM
hu's Avatar
hu
Default How do I remove this part
I took the 10 bolts out. How do I get this piece out. It will not budge.
Old Apr 30, 2007 | 12:42 PM
mgags7's Avatar
The girdle is tough to get out
Try using something to pry it, but make sure it is wide so as to not damage the girdle by spreading out the force.
Old Apr 30, 2007 | 12:47 PM
98vtec's Avatar
moderator emeritus
Default Re: How do I remove this part (hu)
use a rubber mallet and hit it on both sides of the main to break the dowel pins loose. Dont hit it hard. Just tap it on each side until you visually see it break loose. From that point you can use a screw driver to pry it up or you can wiggle it free.
U did unbolt it in sequence, correct?
Old Apr 30, 2007 | 01:21 PM
hu's Avatar
hu
Default Re: How do I remove this part (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
U did unbolt it in sequence, correct?</TD></TR></TABLE>
Yep, followed the helms.
Old Apr 30, 2007 | 01:31 PM
Maharajamd's Avatar
Hu, let me know if you need any help. I am real close to your location..
TeamRiskEG6
Oct 16, 2007 08:44 PM
toguemaster
May 30, 2006 11:07 PM
99teggsr
Apr 19, 2005 10:55 AM
Honda_18
25
Dec 5, 2004 02:38 PM
iwhichisme
Sep 6, 2004 05:22 PM
