Front end problems
Old Apr 30, 2007 | 05:12 AM
preludetospeed's Avatar
Default Front end problems
I just put a set of ground controls and koni yellows and now my front end seems a little lose. Like it feels like when i step on the gas the car wants to togo the right but when i brake it trys to goto the left. No everything on the front end is tight i check it all before i put the car back on the ground. it is a 200 prelude with new tires and the suspension mentioned above. Thanks for helping out.
P.S. could this be cause by the front being a little different it hieght (dont think it is just thought i would tell you what i was thinking)
Old Apr 30, 2007 | 07:10 AM
Default Re: Front end problems (preludetospeed)
no one?? I also notice it if i just lift off the throtle it will pull to the left.
Old Apr 30, 2007 | 07:27 AM
bb4 jdm lude's Avatar
i have a 92 lude and mine does the same things but i have stock everything but lowering springs plus i need new tyrod ends
Old Apr 30, 2007 | 07:31 AM
Maharajamd's Avatar
I was always told if you mess with anything suspension, you should get an alignment...
Old Apr 30, 2007 | 07:34 AM
Default Re: (Maharajamd)
by the way i wrecked my car on the right side being an idiot (won't say what i was doing) and it has never really been right since... and it has the same stuff on it since 92
Old Apr 30, 2007 | 07:49 AM
4WSi_guy's Avatar
if you have it too low you may need a camber kit and an alignment....while your doing that, you might as well get energy susupension bushings...
Old Apr 30, 2007 | 07:51 AM
Maharajamd's Avatar
Default Re: (bb4 jdm lude)
Then yes. You need to go and get some alignment readings and see whats up. You could have done more damage then you think with just a minor accident. Go get it checked out and go from there.
I realized last week I have put 35k on my car without getting an alignment! LOL! I got one and holy good god it drives so much better.
Old Apr 30, 2007 | 08:26 AM
marks_lude's Avatar
is ur front left koni on full tight and your front right on full loose?
make sure they are both equal.
Old Apr 30, 2007 | 08:43 AM
i have previously wrecked mine slightly fender....and everything is the same factory stuff that came with it.....tyrod ends, shocks cv axles
Old Apr 30, 2007 | 09:25 AM
Ok first i would just like to say that A. the car is not that low (1.5 inch or so) and B. i have not hit anything. and i have had 2 alignments in the past 2 weeks and i am afraid of going back for another since they have to do if for free but i like these guys and dont want to **** them off. but i was thinkin the shocks could be set up different so i will check that tonight.
Old Apr 30, 2007 | 10:05 AM
Maharajamd's Avatar
Default Re: Front end problems (4WSi_guy)
I thought I had read somewhere recently that the ES m. mounts or inserts are great, but the bushings are so rigid it actually makes it a uncomfortable ride... And that they are also rated to not last near as long as OEM ones do. Personally, I am just going to get oem bushings....
On another note, we just dropped this sick z6 into a crx the other weekend, and the dude just filled the gaps in his motor mounts with polyurethane caulking. His motor doesn't move at all now lol...and it cost all of 5 bucks..
Old Apr 30, 2007 | 02:23 PM
JDMorDIE's Avatar
Check all the parts that you had to loosen up and tighten up all of them because after dropping mine i had same problem, but mine was because i didnt fit the control arms on right.
rmiller
Jun 1, 2008 03:57 AM
bbbleondacomeup
Mar 11, 2008 01:08 PM
integranator
Sep 18, 2004 12:59 PM
B18_DrpD
Sep 4, 2004 01:03 PM
