lude problem
Old Apr 24, 2007 | 05:40 PM
lazyhenry30's Avatar
Default lude problem
i also have the problem where if i am gassing with the clutch in, when the revving goes down, i hear this rattling, like something is going down a tube. is this normal.
Old Apr 24, 2007 | 05:43 PM
dreed2300's Avatar
Default Re: lude problem (lazyhenry30)
maybe..... Check to see if your exhaust is hitting the heat shield anywhere. If not that listen under hood till you narrow it down to a certain area. Need more info to help you out bro.
Old Apr 24, 2007 | 05:45 PM
Default Re: lude problem (dreed2300)
will do, my friend might help me, so i might be able to jack up the car and have him look for that sound for me. But in side the driver seat, it sounds like it's coming from under the hood
Old Apr 24, 2007 | 05:57 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreed2300 &raquo;</TD></TR><TR><TD CLASS="quote">maybe..... Check to see if your exhaust is hitting the heat shield anywhere. If not that listen under hood till you narrow it down to a certain area. Need more info to help you out bro.</TD></TR></TABLE>
Sounds like a rattly heat shield to me too. Sometimes the cat will start breaking apart on the inside and rattle like that too, but I vote heat shield too. Try tapping them with a wrench to see if it's te same sound.
Old Apr 24, 2007 | 06:09 PM
revvin7's Avatar
My bet would be the heat shield also. My old 240 did the same thing.
Old Apr 24, 2007 | 06:10 PM
Default Re: (revvin7)
where is the heat shield located?
Old Apr 25, 2007 | 05:14 AM
Chris F's Avatar
Default Re: (lazyhenry30)
check between the cat and the body of the car.
Old Apr 25, 2007 | 08:00 AM
Default Re: (Chris F)
cool, once i get some time i will take a look and report back
Old Apr 25, 2007 | 08:29 AM
tgreene2098's Avatar
it could just be a bad cat i had this problem.......when i would start the car and accelerate the exhaust would rattle, replacing your cat isnt exactly cheap tho so make sure if you think thats it
Old Apr 25, 2007 | 06:28 PM
Default Re: lude problem (tgreene2098)
cool... i will keep that in mind, damn. car are so expensive
Old Apr 25, 2007 | 08:43 PM
LudeNEzz's Avatar
Also you could double check the heat shield protectin the alternator from the header. i had a similiar problem with a rattlin noise, thought it was the exhaust and found out it was that dam heat shield!!
Old Apr 25, 2007 | 09:08 PM
streamlineluder's Avatar
stop driving like a jackass and maybe your car won't break
Old Apr 26, 2007 | 11:59 AM
thelonerangers's Avatar
Default Re: lude problem (streamlineluder)
i had a similar noise on my bb6, but it wasn't the heat shield or exhaust like my mechanic thought, my timing belt tensioner broke and my timing belt was bouncing off and hitting the cover.
Old Apr 26, 2007 | 05:11 PM
preludefien
Guest
Posts: n/a
Default Re: lude problem (thelonerangers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streamlineluder &raquo;</TD></TR><TR><TD CLASS="quote">stop driving like a jackass and maybe your car won't break</TD></TR></TABLE>
that has nothing to do with it...
Old Apr 26, 2007 | 06:18 PM
if my car is this bad, i feel sorry for your car
Old Apr 27, 2007 | 05:43 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazyhenry30 &raquo;</TD></TR><TR><TD CLASS="quote">
if my car is this bad, i feel sorry for your car</TD></TR></TABLE>
If his car is so bad, I feel sorry for my car.
So lazyhenry, did you get off your lazy *** and fix the problem yet?
-Chris
Old Apr 27, 2007 | 06:17 AM
marks_lude's Avatar
Default Re: lude problem (Chris F)
if its an h22 could be the autotensioner as well. that would suck
Old Apr 27, 2007 | 09:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
-Chris</TD></TR></TABLE>
will today or the weekend. i am more like busy henry now a day.
but keep in mind i dont know a lot about fixing car so i'm try to see if i can fix it. i'm start with looking at the heat shield and then the cat
Old Apr 27, 2007 | 10:37 AM
Ok so, my friend help me jack it up and found that my flex hose (i think) is broken. But it was too early in the morning so he didn't really try to find the exact problem. I'm bring it in to the shop tomorrow and let my mech look at it and fix the flex hose
NovaRex
Mar 16, 2015 01:36 PM
beastman@
Sep 25, 2007 04:48 PM
the king.
Oct 17, 2006 06:31 PM
Fatty_1775
10
Apr 30, 2004 06:56 PM
PoonHunter
Aug 11, 2003 03:51 PM
