H22a Swap throwing IAT code and vtec solenoid code!
Old Apr 28, 2007 | 04:10 PM
preludedriva's Avatar
Default H22a Swap throwing IAT code and vtec solenoid code!
just got done with another h22 swap in my prelude
obd1 h22a blah blah
Code 10 and 21
i rewired vtec completly and its sitll throwing the vtec code :/
i have no idea what is wrong and why it is throiwng the code still
i even swapped out the vtec solenoid with a prefectly good one
is it because of the IAT code?
Old Apr 28, 2007 | 07:20 PM
prelude_h22vtec's Avatar
maybe its not wired correctly
Old Apr 28, 2007 | 08:33 PM
94vtirozguy's Avatar
no IAT will not cause other code.
The IAT is pretty delicate. Did you replace / damage it when you did the swap ?
Old Apr 29, 2007 | 02:36 AM
Default Re: (94vtirozguy)
its wired fine i had an h22 in it before i even rewired it
ima try to find a one wire IAT sensor i got a buncha 2 wire ones
Old Apr 29, 2007 | 01:21 PM
Default Re: (preludedriva)
anyone else know what could be the problem? i even swapped out ECUs
im totally stumped!
Old Apr 30, 2007 | 10:40 AM
up
Old Apr 30, 2007 | 10:16 PM
Old Apr 30, 2007 | 11:10 PM
preludefien
Guest
Posts: n/a
dude check your wiring and grounds...the **** sucks...are you sure you have it wired to the right pins at the ecu...
Old May 1, 2007 | 12:31 AM
Default Re: (preludefien)
yep it had an h22 in it already i figured i crossed the wires or something so i redid it all
and heres another thing
we swapped the wiring from the solenoid to the pressure switch
so that should throw both pressure switch and solenoid code right? no it still threw just the solenoid code
Old May 1, 2007 | 05:54 AM
sean1121's Avatar
I had it wired backwards when I finished the swap and it didn't throw a code until I tried to hit vtec, and then it was only the code for the solenoid, so it may not give you both codes. Just a heads up.
Old May 1, 2007 | 11:20 AM
Default Re: (sean1121)
still cant figure it out!
Old May 2, 2007 | 01:17 AM
Old May 2, 2007 | 10:31 PM
Old May 4, 2007 | 12:36 PM
up
lvlistchif
Sep 25, 2009 02:43 PM
ZC DOHC CRX
May 20, 2009 10:52 PM
staticrex
Jun 5, 2004 01:50 PM
