need help!! please
Old Oct 8, 2007 | 09:43 PM
rookshot06's Avatar
Default need help!! please
heres the deal. something is wrong with my prelude its a non sh AUTO.its a 98 prelude. i did a tuneup on the car(cap,rotor,plugs,fuel filter,oil) instead of 5w30 i used 10w40 cuz i had no oil and it was late. heres the problems
when driving the car it has no power and it feel very very sluggish
2nd is the exhaust keeps putting out all this blk sutt on the rear bumper and if u gun the car is leave a cloud of blk smog.. please if any1 knos whats wrong please pm me or respond back here. thanks.
Old Oct 8, 2007 | 09:47 PM
dagle's Avatar
Default Re: need help!! please (rookshot06)
you're burning.. you guessed right. OIL ! change your oil again and see what happens.. i use 10w30 mobil1, i run rich too but mine is manageable
Old Oct 9, 2007 | 07:57 AM
dominican luder's Avatar
its most likely your pistons rings are gone.
Old Oct 9, 2007 | 02:12 PM
preludefien
Guest
Posts: n/a
Default Re: need help!! please (coolicedragon)
you are loosing compression...need new rings...do a compression test
Old Oct 9, 2007 | 03:25 PM
rookshot06's Avatar
thanks for the help. also it keeps throwing a toorich.too lean code and misfire codes.
Old Oct 9, 2007 | 04:36 PM
slamdlude's Avatar
Sounds like you might not have put the plug wires back on in the correct order.
Old Oct 9, 2007 | 05:33 PM
rookshot06's Avatar
Default Re: need help!! please (slamdlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rookshot06 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help. also it keeps throwing a toorich.too lean code and misfire codes.</TD></TR></TABLE>
heres how i have it from the belt side is 1
on if u were to look at the dist on the side from bottom from left to right
BL-1 BR2-TL3-TR4
Old Oct 9, 2007 | 07:30 PM
Cottonwoodz's Avatar
Default Re: need help!! please (dagle)
Doods running rich. Has nothing to do with buring oil
Old Oct 10, 2007 | 07:50 PM
rookshot06's Avatar
so any help?? what can cause it to run ricH?? o2??
Old Oct 10, 2007 | 08:40 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolicedragon &raquo;</TD></TR><TR><TD CLASS="quote">its most likely your pistons rings are gone. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">you are loosing compression...need new rings...do a compression test</TD></TR></TABLE>
That should never be the first suggestion. His problem is the rich code. Try a new o2 sensor. Check to make sure the catalytic isn't clogged....
Old Oct 11, 2007 | 12:05 AM
preludefien
Guest
Posts: n/a
Default Re: need help!! please (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
That should never be the first suggestion. His problem is the rich code. Try a new o2 sensor. Check to make sure the catalytic isn't clogged....</TD></TR></TABLE>
didnt see anything abt that cel
Old Oct 12, 2007 | 12:50 PM
rookshot06's Avatar
Default Re: need help!! please (preludefien)
the car is throwing a too rich/too lean cel also misfire cels. cat. was just replaced. if its the o2 wouldnt the cel light come on for that?
Old Oct 25, 2007 | 07:33 PM
rookshot06's Avatar
well i finally got the cel light off by changing the o2 sensor. but the car is still spitting out blk stuff(alot of it). also car still kinda studders when taking off. any help would be great.
thanks
Old Oct 25, 2007 | 09:42 PM
Hawkze_2.3's Avatar
Check your cam and ignition timing, the other 02 sensor and maybe the cat.
Old Oct 26, 2007 | 06:33 PM
rookshot06's Avatar
Default Re: need help!! please (Hawkze_2.3)
did all that changed both o2 brand new cat.. also i pulled the plugs out and for some reason cyliner 4's sparkplug is blk the other 3 is koo. can this be caused by a bad fuel injector??
a2dadamm
Apr 23, 2012 08:33 AM
bhensoH22
Jul 3, 2009 05:34 PM
civic_freak
Apr 26, 2004 07:35 PM
-RedneckDave-
Feb 3, 2003 07:53 PM
cjohnson_2
Oct 17, 2002 08:40 AM
