4 CEL Codes, Need Help!!
Old Oct 3, 2007 | 08:39 AM
OhWUNshlude's Avatar
Default 4 CEL Codes, Need Help!!
Ok, I went to my nearest VIP for a engine diagnostic cause of my CEL. Heres what I got.
1. Multiple random misfires.
2. Misfire Cyl. #1
3. Misfire Cyl. #2
4. Misfire Cyl. #3
They are telling me it is caused by either a fault wire(s), plugs, coil, vacuum leak, bad injector, or High or Low fuel pressure.
These people have no idea what they are talking about, which is why im here. Please tell me what you think it is. I have recently changed the plugs, wires, cap/rotor because of the last time I got my CEL checked all I was told it was "misfiring"... And the light is STILL on...
Old Oct 3, 2007 | 08:41 AM
mgags7's Avatar
this code is tough to find.
Have you replaced the fuel filter? How many miles are on it??
Old Oct 3, 2007 | 08:48 AM
Default Re: (mgags7)
No I have not, just hit 83k today, purchased at 65k
Old Oct 3, 2007 | 08:56 AM
98vtec's Avatar
moderator emeritus
Default Re: (OhWUNshlude)
this is the list of things i have told him to do since he just got the car not long ago without any prior record of things being replaced:
Clean EGR ports
replace fuel filter
do a valve adjustment
check the plug gap
Old Oct 3, 2007 | 09:02 AM
Default Re: (98vtec)
^^^ genius
Old Oct 3, 2007 | 09:51 AM
Duane_in_Japan's Avatar
Since you have already tuned it up you could have a lean misfire due to dirty fuel injectors, you will need to have it looked at by a qualified shop who knows how to read spark lines on an oscilloscope, I also agree with the recommendations above, be careful on the valve adjustment, these cars are touchy, you should have just under 1 volt coming out of the MAP sensor at a fully warmed up idle, no fans and no accessories on.
Old Nov 29, 2007 | 01:33 PM
Where is that write up on cleaning ports? Cant find it!
Old Nov 29, 2007 | 01:50 PM
prelude_93vtec's Avatar
try a tune up
Old Nov 29, 2007 | 02:32 PM
Acidcrakker's Avatar
Search, not trying to flame, but Im in the process of cleaning my egr ports, and I found a good write up on the Honda Accord forum.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OhWUNshlude &raquo;</TD></TR><TR><TD CLASS="quote">Where is that write up on cleaning ports? Cant find it!</TD></TR></TABLE>
Old Nov 29, 2007 | 09:37 PM
SEARCH GODDAMN NOOB!!!! just kidding. dont wanna break the new rulez
anyways mgags had a nice write up on it
RIGHT HERE
slo gto
Aug 10, 2010 02:55 PM
kaotikvizion
Jun 3, 2008 11:19 PM
lcjarrett
Feb 1, 2006 05:22 PM
djtony5
Jul 29, 2005 12:45 AM
