bad compression?
Old Oct 9, 2007 | 02:25 PM
SilverPanda's Avatar
Default bad compression?
is 175 across the board a little low compression for my h22a4?
Old Oct 9, 2007 | 03:01 PM
Default Re: bad compression? (SilverPanda)
no one knows?
Old Oct 9, 2007 | 03:16 PM
Prudz_lude's Avatar
average ish. how many kms? new they should be up at 230 or 235
Old Oct 9, 2007 | 06:05 PM
Default Re: bad compression? (Prudz_lude)
its at 94,000 miles so about 150,000 kilometers
Old Oct 9, 2007 | 07:11 PM
ECX's Avatar
ECX
* B A N N E D *
Not to threadjack, but I compression tested my h23a1 (head was rebuilt at 78k, now the motor has 166k on) and got around 220 all the way across.
Old Oct 9, 2007 | 07:19 PM
dagle's Avatar
Default Re: (ECX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECX &raquo;</TD></TR><TR><TD CLASS="quote">Not to threadjack, but I compression tested my h23a1 (head was rebuilt at 78k, now the motor has 166k on) and got around 220 all the way across. </TD></TR></TABLE>
how does that help at all? lol
onto the pt: that is a bit low, was the compression test done at WOT?
Old Oct 9, 2007 | 07:22 PM
98vtec's Avatar
moderator emeritus
Default Re: (dagle)
as long as they are all the same, you are ok. Gauges read differently, just like dyno's.
Old Oct 9, 2007 | 10:02 PM
lude98SH's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">as long as they are all the same, you are ok. Gauges read differently, just like dyno's.</TD></TR></TABLE>
There is a low spec in the helms though even without variance. However hes not even close to that.
Old Oct 9, 2007 | 10:11 PM
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">
There is a low spec in the helms though even without variance. However hes not even close to that. </TD></TR></TABLE>
so basically im ok then?
Old Oct 9, 2007 | 10:25 PM
AaronW's Avatar
Default Re: (SilverPanda)
Yeah, you're fine.
It's more important that the numbers are close together, more so than what the numbers actually are.
Mr.OB*GYN_Rhett
Aug 17, 2006 10:54 PM
floatfisher
May 30, 2006 10:09 PM
peel17
May 29, 2005 01:19 AM
Mr.Integra
Apr 22, 2004 07:56 PM
DOHCarp
Sep 11, 2003 07:10 PM
