Spark Plugs
Old Oct 4, 2007 | 03:04 PM
Mike1995HondaPrelude's Avatar
Default Spark Plugs
Hi, I own a 1995 Honda Prelude VTEC. I think I need to change the spark plugs. When and how often should I change them? What kinda should I buy? Will I notice a difference with the new plugs?
Thanks!
Old Oct 4, 2007 | 04:03 PM
Acidcrakker's Avatar
Default Re: Spark Plugs (Mike1995HondaPrelude)
Take them out and inspect them. You can probally use google and search what a bad plug looks like. I just did mine. I used denso, and someof them needed to be gapped right.
Old Oct 4, 2007 | 06:19 PM
shadow29485's Avatar
Don't buy anything American.....use the dens. or ngks.
I'm not trying to offend anyone patriotic, but our economy is supported by free trade, not by us, as a U.S consumer that purchases something that's going to fail in the long run. We as a U.S citizen are going to benefit within the economy either way....so use what the japs first designed it for.....Longevity, and go with a plug that's marked "Made in Japan."
Remember?......Honda...."Performance first"
If anyone would care to flame me, that's fine.......
Just think really hard about where your Computer, T.V., microwave, toaster oven, Ipod, Cd player, dvd player, cell phone, X-box, sega, etc., have come into play with our technology.
Almost all of the listed above, will have a trace, right back to where the original origin has provided our trust in a comfort of our tech.. Made in Japan....they build it smarter.....we just market it better.
I love my Kenmore washer and dryer...That I've had to replace (3 times).....I wish I could purchase a "Hitachi", "Orion", "Sony", washer and dryer.
I wouldn't have to be pumping quarters into a machine next to someone that's living off of my pay check....while selling drugs, and eating a porter house steak, while I work 70+hrs. a week to support the sorry *** lazy bastards that are driving a Denali smoking up our tax payers money, and living off of us, hard working individuals, morally.
I'm a little on a rant so please forgive me........but it's so ******* true.
All and all, go for the ngk, ngk iridiums...or the densos. If gapped correctly and all is good with your engines performance, they won't let you down.
Ta, ta....
Old Oct 4, 2007 | 06:44 PM
wegotmorrison's Avatar
Default Re: Spark Plugs (shadow29485)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow29485 &raquo;</TD></TR><TR><TD CLASS="quote"> Don't buy anything American.....use the dens. or ngks.
Ta, ta....</TD></TR></TABLE>
You offend no one..we all no american auto parts SUCK
Old Oct 4, 2007 | 08:24 PM
Default Re: Spark Plugs (wegotmorrison)
Should i notice a difference after changing them if they are old and need changing?
Old Oct 4, 2007 | 08:28 PM
Depends on how bad they were.
Old Oct 5, 2007 | 04:50 AM
mattsnooz's Avatar
no real horsepower gain, but it will be *peppier* if thats the even the word.
It will probably accelerate a touch easier
Old Oct 5, 2007 | 02:16 PM
Default Re: Spark Plugs (mattsnooz)
Old Oct 5, 2007 | 03:16 PM
Duane_in_Japan's Avatar
Better read the side of that NGK, it might just say MADE IN USA. Honda OEM = NGK. One cheap JDM NGK = $5.50 over here.
Old Oct 5, 2007 | 06:14 PM
Default Re: Spark Plugs (Duane_in_Japan)
so do i just got to autozone and request some NGKs? Do u need a specific heat range or anything else? should i replace wires?
Old Oct 5, 2007 | 06:21 PM
It wouldnt hurt to replace your spark plug wires. And yes auto zone. Just go there tell them your make modle and year and they will read you off a list of whats available.
Old Oct 5, 2007 | 06:24 PM
96vtecI4's Avatar
Any info on the Zex nitrous plugs? I'd like to pick up a set for my nitrous car, not sure if they're any different then NGK though.
Old Oct 5, 2007 | 07:57 PM
AndyD's Avatar
Recommended plugs:
NGK PZFR6F-11
Denso PKJ20CR-L11
Old Oct 5, 2007 | 10:40 PM
Pullig's Avatar
Default Re: Spark Plugs (AndyD)
on my jdm h22a i like to run the 1 step colder plug
the BKR7e .... part number is 6097 just tell advance autoparts that number and they can find them
Old Oct 6, 2007 | 12:50 AM
117's Avatar
117
PZFR6F-11 is the standard platinum plug, so it's a bit expensive. If you want to use the equivalent copper plug pick up a ZFR6F-11.
For a stock car, there is really no benefit to running one step colder. In fact, you should run as hot a plug as you can get away with. One step colder is a 7 heat range, so PZFR7F-11 for platinum, ZFR7F-11 for copper.
Old Oct 6, 2007 | 06:18 AM
Default Re: (117)
I would read the old plugs before I decided to go up or down a heat range, can you explain what one looks like inside for us. Go with NGK Platinium or Iridiums for long term use.
Old Oct 6, 2007 | 12:36 PM
Default Re: (Duane_in_Japan)
Replace the wires?
Old Oct 6, 2007 | 04:00 PM
Default Re: (Mike1995HondaPrelude)
As a minimum, at night time, pull a wire up off of the spark plug until that cylinder dies, move the sire around while it is still down in the plug well and see if you can see spark jumping from the side of the wire, if not really noticable then they should be ok but they are a tune up item and if they have not been changed in a while, then change them. You can also spray them down with a mist of water and see if spark jumps out anywhere along the length of the wire too.
Si Speed's Avatar
If you're throwing codes and have pistons misfiring before you change them, then you DEFINITELY will. I speak from experience.
NGK FTMFW!
If you change your wires, get NGK's specifically or go to Hond and get wires. Do NOT get other brands from auto stores. I went through several brands on my old Accord, not to mention what my dad went through on his cars. Napa, Duralast, Bosch, etc., none of them are near as good as OEM.
Old Oct 6, 2007 | 08:00 PM
Default Re: Spark Plugs (si_speed)
I agree....Bosch is about the closest thing that you'll come to an ngk or denso....there German.... They build great rifles and tanks, but they lack on the automobile stand point...Ta,he,he. look at Dodge, jeep, crys.
I'm sure that I don't just speak for myself, but it's a good thing that the japs didn't figure out splitting the atom first, if so we'd be all in deep ****....They would've made "little boy" and "fat man" the size of a nickle, with the same outcome. I think that right....not sure though...lol
Old Oct 6, 2007 | 10:23 PM
AaronW's Avatar
Go with the regular copper NGK's for your car.
They're cheap, pre-gapped, and OEM.
Old Oct 7, 2007 | 01:24 AM
Default Re: (AaronW)
Stay away from Bosch on non-Bosch cars.
Old Oct 7, 2007 | 03:58 AM
BlackCatt's Avatar
I have used NGK spark plugs for years on my 2nd gen and my current 4th gen, and love them. As to how often to replace them, i change them every 5000k, probably overkill but just my preference.
Old Feb 26, 2008 | 08:46 PM
tgreene2098's Avatar
Default Re: Spark Plugs (BlackCatt)
are the bosch iridiums any good?
asinclado
27
Jan 17, 2024 09:22 PM
W95civicEXcoupe
11
Oct 27, 2014 10:01 AM
nickolas388
Oct 26, 2005 08:01 PM
nsx-Animal
Jul 30, 2002 04:22 AM
reefer_bob
Jul 22, 2002 12:32 PM
