ATTS Help Please
Hi Guys,
Newbie here so please be gentle
Bought a BB6 Type S and today the ATTS light only came on, no CEL light, so searched on here and pulled the codes....
ATTS codes are 42 and 78 I think, forgive me its the first time I have did this. The ABS light also flashed and from what I can tell the codes are 63 and 25?
Now I have recently changed the suspension to Tein SS coilovers, but ran these for 2 days and only today the light came on.
Have checked the petrol cap, and the tyre pressures and both are fine, i'm confused, any suggestions?
I want to sort these out rather than just reset the ECU which I have tried and doesn't seem to sort out the issues
Cheers in Advance
Cheers in Advance
When ever you get the ATTS light and the ABS light you troubleshoot the ABS first. I dont have my helms with me right now and i dont know the codes of the top of my head but maybe some here can tell you what codes those are.
Thanks for the quick response,
The ABS light doesn't come on, only when I pull the codes, it then flashes, so I need to try and sort these out and hopefully the ATTS is sorted at the same time?
Right after racking my brains, guess what I found?
A nail wedged into my front tyre, swapped it around with the rear, reset the ecu and cleared the codes doing the steering wheel trick and guess what no more ATTS light!!!!
Cant beleive its so dam sensitive
samyd25
Nov 14, 2013 02:42 PM
