Problem With H23 Stock Headers
Old Oct 7, 2007 | 09:19 PM
9.3.S.I.L.U.D.E.'s Avatar
Default Problem With H23 Stock Headers
Alright i got a 1993 Honda Prelude Si and the Screws of the headers that go into the head dont tie they always get loose and i always tight them and i took it to some shop and they said its probly the greedy cat back exaust system that is clogging up but i dont think so because i took out the catalitic converter........ so what do i do !!!!!!!!!!!!!!!!!!help
Old Oct 7, 2007 | 09:37 PM
Acidcrakker's Avatar
Default Re: Problem With H23 Stock Headers (9.3.S.I.L.U.D.E.)
My question is how would your exhaust system loosen up your header bolts.
Old Oct 7, 2007 | 10:02 PM
mattsnooz's Avatar
Default Re: Problem With H23 Stock Headers (Acidcrakker)
from vibration.
Old Oct 7, 2007 | 10:06 PM
mattsnooz's Avatar
Try some lock-tight on the threaded part of bolt (just a touch of lock-tight, don't go crazy with it)(red liquid that helps bond bolts/threads together in case if you haven't heard of lock-tight)
when you want to pull it off just spray with a penetrate like liquid wrench, and crank them with some leverage
Oh *edit* if vibrations are that bad check your rubber exhaust ties and see if they are even still rubber. If not, go buy RUBBER ones. (there should be about 3 or 4 if I remember correctly). If they are made of metal they don't dampen the vibration as well and cause alot of unnecessary unmentionable B.S.
Old Oct 7, 2007 | 10:23 PM
Hawkze_2.3's Avatar
You only have one header, and I doubt it has anything to do with your 'greedy' exhaust. Just get some OEM exhaust nuts (somewhat self-locking), torque them to the proper specs, and they should be fine.
l.u.d.e.51
Jan 14, 2008 07:26 PM
IAluder95
Feb 19, 2007 04:23 PM
fonioflip
Apr 21, 2005 02:38 PM
eghondasforlife
Apr 1, 2005 11:03 PM
munscher
May 27, 2003 11:30 AM
