Brake Problem.
Old Oct 1, 2007 | 07:29 PM
Mike1995HondaPrelude's Avatar
Default Brake Problem.
I have a 1995 Honda Prelude VTEC. The brake light located under the ABS light is now on all the time. The day before it persistently stayed on, it would flicker in a sharp, fast turn. The brakes do make screeching noises every once in a while and the right front wheel makes a noise (squeaks) every time it revovles, but it isn't really loud. The light usually only comes on when i engage the E-brake. However, when i do engage the E-brake, the light just shines brighter. What do you think the problem could be?
Thanks!
Old Oct 1, 2007 | 08:45 PM
H22Luda720's Avatar
Default Re: Brake Problem. (Mike1995HondaPrelude)
Sounds like at first your brake fluid was just low enough to trip the sensor on turns, now its tripping the sensor all the time, check your fluid, brake noise could be low pads which explains where all the fluid is.
Old Oct 1, 2007 | 08:50 PM
Default Re: Brake Problem. (H22Luda720)
thanks, i'll do that. I just had them worked on. The place seemed real professional. I hope they filled it right..
Old Oct 1, 2007 | 09:07 PM
H22Luda720's Avatar
What exactly did they do?
Old Oct 1, 2007 | 09:27 PM
yep, check fluid. it was low. filled it a bit. turned on car and it was fine. They replaced the master cylinder. I also found one of their rags down in my engine bay...
thanks for help.
Old Oct 1, 2007 | 11:11 PM
H22Luda720's Avatar
keep an eye out for leaks! just incase
pfourtythree
Apr 10, 2007 10:52 AM
grandmasterflash
Dec 28, 2005 05:55 AM
sullycrx
Nov 16, 2005 09:48 PM
.water
Jun 11, 2005 12:06 PM
Padronis
Jun 29, 2002 07:00 AM
