Need to know why....
A little is fine but oil does expand dont know how much> the problem gets when pressure gets to high you blow out seals. Also I think not sure windage becomes a problem.
if your oil level is too high, the oil will foam up from getting beat around by the crankshaft. when the oil is foam, and not liquid, the pump cannot push it through the motor. this will starve your engine of oil.
this is called "cavitating the pump"
Modified by prelude_h22vtec at 9:04 PM 10/2/2007
