question about powersteering
Old Jan 9, 2008 | 11:12 AM
vietdragontekx's Avatar
Default question about powersteering
i had the pump and reservor removed for about half a year now. so there no power steering at all. now i want to go back to power steering. Do i just put pump back on and reservor and line and etc and just fill with power steering fluid and start the car? Or there something i need to do before i do all this?
Old Jan 9, 2008 | 11:23 AM
98vtec's Avatar
moderator emeritus
Default Re: question about powersteering (vietdragontekx)
given that you took out everything without kinking a tube etc, then you should be able to just put it back like you had it. be sure not to forget about the cooler.
Old Jan 9, 2008 | 12:57 PM
Default Re: question about powersteering (98vtec)
cooler? i only took out the rubber line going to the hard line near the back of firewall and the reservor and ps pump.
Old Jan 9, 2008 | 09:23 PM
Hawkze_2.3's Avatar
Yeah, there's a PS cooler in front of the radiator...but if you just put everything back in how you had it you should be able to get it working.
Old Jan 10, 2008 | 07:00 AM
mgags7's Avatar
If I were you, I'd fill it, then use the helms' draining procedure once to get that stagnant fluid out, and get some fresh stuff in there. Plus, that will aid in burping the air out as well.
Old Jan 10, 2008 | 11:14 AM
Default Re: (mgags7)
i don't have a helm manual , do u know the procedure?
Old Jan 10, 2008 | 11:24 AM
mgags7's Avatar
basically, you just set it up so that 1) the low pressure return hose is venting into a waste container and 2)you didn't leave anything open that's gonna spill
Old Jan 10, 2008 | 11:37 AM
so if i get this right, i hook everything up, fill the reservor then remove the return ine and put it on a waste container and turn on the car?
Old Jan 10, 2008 | 11:41 AM
mgags7's Avatar
you don't want to fill the reservoir with new fluid if you're just gonna drain the old crap out.
There is a special procedure for it, I really recommend getting a manual. I don't remember it off the top of my head, and I'm not sure you're ready to figure this out alone.
Old Jan 10, 2008 | 12:10 PM
thx
Old Jan 10, 2008 | 02:25 PM
mgags7's Avatar
found it
Old Jan 10, 2008 | 02:30 PM
thx a lot
oneheadlight
Nov 22, 2015 05:31 AM
arziffel
Jun 8, 2012 09:34 AM
19dabeast85
Jul 14, 2006 01:24 PM
rasinhell
13
Jan 30, 2005 09:15 PM
ActiveAero
Aug 11, 2003 12:27 PM
