help with starting issue
Old Jan 19, 2008 | 10:08 PM
otsegolectric's Avatar
Default help with starting issue
hey, I recently had my engine rebuilt and now i'm having problems starting. Every once in a while it will start perfectly fine. but mostly it will start up once and if i dont give it gas it will bog down. and after it boggs i can try as much as i'd like and it will just crank. it will turn over every once in a while but just for a second but it wont stay running. I have a new starter, new spark plugs and wires, and the car has spark and fuel. any help on what else may happen? or if i need to post new info??
h23 94 lude.
Old Jan 19, 2008 | 11:54 PM
Default Re: help with starting issue (otsegolectric)
no help in the middle of the night? lol i'll check back tomorrow.
Old Jan 20, 2008 | 06:06 AM
mattsnooz's Avatar
So you tried all your spark plugs on a part of the block while you crank your car to see that they all have spark?
So the starter you replaced was the solinoid?
If you have a multimeter you should test the resistances on the coil pack.
>.6ohms for primary and 18k ohms accross the secondary coil.
Sounds like an intermittant problem or no? Does it start better in any better weather conditions??
Old Jan 20, 2008 | 07:16 AM
vlang29's Avatar
is the problem worse when it's cold? If so, it's probably the Fast Idle Thermo Valve
Old Jan 20, 2008 | 12:05 PM
Default Re: help with starting issue (vlang29)
hot or cold it doesnt matter. how is it i test the coil? its basically intermittent that it actually starts and normally doesnt. ya the solinoid was replaced.
Old Jan 20, 2008 | 06:37 PM
anyone else have any input?
Old Jan 21, 2008 | 04:06 PM
new update. decided to replace spark plug wires and looked at the spark plugs and the plug closest to the passenger side was black on the first like centimeter of it. the rest had wet gas on that portion. all but the first was wet with gas. replaced the main relay today too. any suggestions?
yOnKiNaToR
Mar 26, 2009 05:19 PM
98civichb
10
May 22, 2008 05:26 PM
Lb1atx
Jul 27, 2007 04:52 PM
CWITR
May 3, 2005 04:38 PM
Honda Sport
Jun 4, 2003 05:27 PM
