Spark Plug Issue>?
Old Jan 16, 2008 | 01:09 AM
Seroga415's Avatar
Default Spark Plug Issue>?
I have a lude with a straight pipe instead of the muffler. I just bought it. The throttle timing is retarded a bit when i gas it, the sound is loud and obnoxious unless i barely add pressure to the gas pedal, but for some reason that slows my car down rather than make it slightly accelerate. What could be wrong. Also my headlights are wobbly because the stud is loose from the upper mounting socket, how can I make a simple fix ? $ tiny bulbs on the spoiler for the light when i press the brakes dont work, what would be the cheapest replacement. Any suggestions???
Thanks.
Old Jan 16, 2008 | 02:37 AM
Acidcrakker's Avatar
Default Re: Spark Plug Issue>? (Seroga415)
For the straight pipe you can replace it with a high flow cat or a reg. cat.
As for the loud exhaust issue, you can get a resonator, which will tone done the exhaust.
For your middle tail light, try new bulbs from Pepboys or something that should help.
For the most part, when fixing your car it wont be cheap.
Buy quailty parts. Remember you get what you pay for.
Old Jan 16, 2008 | 06:34 AM
vlang29's Avatar
getting any cel codes?
Old Jan 18, 2008 | 01:49 AM
Seroga415's Avatar
Default Re: Spark Plug Issue>? (vlang29)
whats that?
Old Jan 18, 2008 | 03:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seroga415 &raquo;</TD></TR><TR><TD CLASS="quote">whats that?</TD></TR></TABLE>
Cel code is when your check engine light comes on. There is a little jumper harness in your car that you can use to check why the Check Engine Light came on
Old Jan 18, 2008 | 05:50 AM
M2B4's Avatar
Default Re: Spark Plug Issue>? (Acidcrakker)
for when u ask...the harness is behind the cd player in the dash its a small 2 pin blue plug. take and put a paper clip in both end to close the circuit. then put the car in acc mode. you check engine will flash a series of flashes to indicate which code it it. 1 long flash = 10 1 short = 1. add up the flashes and you have your code number.
Old Jan 18, 2008 | 09:27 AM
vlang29's Avatar
Default Re: Spark Plug Issue>? (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">for when u ask...the harness is behind the cd player in the dash its a small 2 pin blue plug. take and put a paper clip in both end to close the circuit. then put the car in acc mode. you check engine will flash a series of flashes to indicate which code it it. 1 long flash = 10 1 short = 1. add up the flashes and you have your code number.</TD></TR></TABLE>
correct, except the ign. key needs to be in the ON position. But you don't need to start the car to check the codes
Old Jan 18, 2008 | 09:29 AM
You can check codes anytime.
There was times where I was just leaving the jumper harness plugged in to see if i was throwing any new codes.
Old Jan 18, 2008 | 09:31 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seroga415 &raquo;</TD></TR><TR><TD CLASS="quote">I have a lude with a straight pipe instead of the muffler. I just bought it. The throttle timing is retarded a bit when i gas it, the sound is loud and obnoxious unless i barely add pressure to the gas pedal, but for some reason that slows my car down rather than make it slightly accelerate. What could be wrong.
Sounds like the timing might be off...
Old Jan 19, 2008 | 03:40 AM
mattsnooz's Avatar
I assume he doesn't want a muffler??? A MUFFLER would probably MUFFLE down the sound a bit wouldn't it?
But the resonator will help a bit and a regular non gutted cat would help by restricting the flow of exhaust (which is what you need to tone that loudness down)(or by using dapening equipment like muffler etc)
DeLSoLRo
13
Aug 23, 2012 02:30 PM
91_gsr
May 4, 2012 09:15 AM
joe3228
Jun 17, 2009 06:27 PM
mdpalmer
Oct 4, 2004 12:19 PM
Del_Slowest
Dec 14, 2003 07:54 PM
