AFC Neo
Old Jan 17, 2008 | 06:40 PM
twiztid00002's Avatar
Default AFC Neo
has anyone ever used a afc neo or heard of anyone using it. if so, is it better or worse than the vafc?
Old Jan 17, 2008 | 07:20 PM
ne4spe's Avatar
Default Re: AFC Neo (twiztid00002)
yeh i got one and i wish i would have researched it b4 i bought it. i never had the first 2 models but from what i read its basically the same principle with more options. and jus like the first two models it needs to be tuned to get full use of its features
Old Jan 17, 2008 | 07:21 PM
Default Re: AFC Neo (ne4spe)
why dont u like it?
Old Jan 17, 2008 | 07:27 PM
ne4spe's Avatar
i would like it if i could tune it myself but im not. i hate to admit it but i bought into that whole pro tuning and also the simple tuning feature that you're supposed to be using if you yourself tried to tune it. well when i got it i read up on how to TRY to tune it in the simple mode. i lowered my vtec engage and without the correct air map my check engine light came on so i just got it reset and now its just sitting on my dash until i take it to get tuned. IMO i wouldnt get it unless you were ready to take it to a dyno soon after.
Old Jan 17, 2008 | 07:35 PM
vlang29's Avatar
which cel code did you get?
if you engage vtec too low, you will get code 22, vtec oil pressure switch.
But definitely, afc's aren't worth the money unless they get tuned with a wideband and a dyno.
Old Jan 17, 2008 | 07:40 PM
ne4spe's Avatar
Default Re: AFC Neo (vlang29)
im ob2 so i got it checked out and i figured it was because i set it too low becuase the code stated it was a vtec malfunction. so now i gotta wait to tune it but i just dropped some cash on a camber kit so that'll have to wait
Old Jan 17, 2008 | 08:06 PM
vlang29's Avatar
how low did you set it?
Old Jan 17, 2008 | 08:30 PM
ne4spe's Avatar
brought it down to 3500 jus to test and it came right on. i had it at 4700 at first but vtec didnt pull as hard there either so i jus have to wait to tune
Old Jan 17, 2008 | 09:05 PM
vlang29's Avatar
yeah, my cel will come on anything lower than probably 4200-4300. i have it set now at 4700, but h23 will take vtec at a little lower rpms. The h22 with stock internals needs a few more rpm's to make use of the more aggressive cam profile..
a hundred or two rpm's may help, but vtec does nothing at too low of rpms.. i bet your nose hit the wheel when you had it set at 3500
Old Jan 17, 2008 | 09:11 PM
98vtec's Avatar
moderator emeritus
i tuned my buddies h22a the other day and the graph showed it liking vtec best at 4200 rpm, weird i know.
Old Jan 17, 2008 | 11:25 PM
vlang29's Avatar
Default Re: AFC Neo (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">i tuned my buddies h22a the other day and the graph showed it liking vtec best at 4200 rpm, weird i know.</TD></TR></TABLE>
stock internals?
Old Jan 18, 2008 | 02:27 AM
ne4spe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, my cel will come on anything lower than probably 4200-4300. i have it set now at 4700, but h23 will take vtec at a little lower rpms. The h22 with stock internals needs a few more rpm's to make use of the more aggressive cam profile..
a hundred or two rpm's may help, but vtec does nothing at too low of rpms.. i bet your nose hit the wheel when you had it set at 3500</TD></TR></TABLE>
yeh my nose was damn near in the windshield
Old Jan 18, 2008 | 06:51 AM
98vtec's Avatar
moderator emeritus
yep
h22a
AEM CAI
stock header
Skunk2 IM
Apexi N1 catback
my tuning with crome
Old Jan 18, 2008 | 09:24 AM
vlang29's Avatar
impressive!
Old Jan 18, 2008 | 09:34 AM
98vtec's Avatar
moderator emeritus
yea it made great power. Graph is very solid for such a mild bolt on setup.
just remember that this is a full tune with crome....not an afc
Old Jan 18, 2008 | 09:43 AM
Hawkze_2.3's Avatar
stock header
Good tuning, must have been a healthy engine too.
Old Jan 18, 2008 | 10:00 AM
98vtec's Avatar
moderator emeritus
Default Re: AFC Neo (Hawkze_2.3)
the only thing that bugged me was the lean spike. No matter what i did, it wouldnt go away, lol, so i said expletive it. The engine appeared to like it anyway
Old Jan 18, 2008 | 10:05 AM
Hawkze_2.3's Avatar
Haha, yeah it looks like the power also jumped whenever the A/F did
Old Jan 18, 2008 | 10:07 AM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">full tune with crome....not an afc</TD></TR></TABLE>
&lt;--Jealous
Old Jan 21, 2008 | 06:48 PM
snobordboy's Avatar
Moderator
I have one basically to drop my vtec point since I have the H23 tranny on an H22, and didnt want to drop vtec on the 1-2 shift.
At some distant point I will be building and boosting, so I will have a properly tuned ems then.
ef9wpb
Jul 15, 2004 10:30 AM
swlabhot
Jun 21, 2004 02:30 PM
swift535
May 25, 2004 10:21 AM
pbizzlegsr
Mar 8, 2004 03:38 PM
Sukebei Oni
Feb 5, 2003 11:22 PM
