TPS problem
Old Jan 7, 2008 | 05:36 AM
wstsydr's Avatar
Default TPS problem
Hey guys, i have searched and didnt find anyone with my same problem, anyways, i have a 94 h23a auto prelude, it is throwing a #7 CEL which is TPS. I tested the TPS and it was showing ~.2 at idle and ~3.02 WOT which i know are unacceptable to the ECU hence the code. Well i had another one on the old h23 i had to remove from this car and swap and put it on, this one got ~.3 at idle and ~2.5ish at WOT. I know that it is in the realm of possiblities that both of these could be bad, i dont remember a CEL from the old engine being in, but that has been a few years ago.
So to my question, how possible is it that these TPS are both bad or is there something else that i am overlooking. And before it is asked yes i am getting 5v from the power wire with it grounded both at the plug and body. This is also the only CEL code that is being thrown, i was getting a knock sensor code, but thats because it was broken in half, but i have replaced it with no recurrance of the code.
Thanks for any help and ill provide any more info that i can.
Old Jan 7, 2008 | 05:38 AM
wstsydr's Avatar
Default Re: TPS problem (wstsydr)
Oh yeah, the other problem it has is that it will just die out of nowhere, i am hoping this is due to the voltage problem with the TPS, but it will usually just start right back up and i can usually keep it going if it tries to bog down by giving it gas.
EDIT: one more question, i am now researching to get another TPS, should this be the same TPS that is in pretty much any honda? I have looked thru the lists and they dont say specifically the h23a and it looks like they just copy/paste the list from one to another.
Modified by wstsydr at 8:58 AM 1/7/2008
Old Jan 7, 2008 | 07:54 AM
Hawkze_2.3's Avatar
Have you tried adjusting the TPS to get a different voltage?
I know Honda used the same TPS on many cars through the 90's, maybe even the late 80's/early 2000's. I got one from an old Accord at a junkyard and it was the same as my 95 H23 TPS. It's definately not H23 specific
Old Jan 7, 2008 | 08:39 AM
wstsydr's Avatar
Default Re: TPS problem (Hawkze_2.3)
Yeah, i had the screws loose and when i would go WOT i could move the TPS and get slightly different readings, but still not within the 4.5 range, it would get to the maxes that i listed earlier.
Old Jan 7, 2008 | 08:40 AM
wstsydr's Avatar
And yeah, ill check my TPS on my 97 Teg then, maybe it will be right and i can at least know that i have a good one in place to test with. Thanks for that info
Old Jan 7, 2008 | 10:42 AM
wstsydr's Avatar
afternoon bump... TTT
Old Jan 7, 2008 | 12:58 PM
wstsydr's Avatar
The before i leave work bump... i know that i need to test with a known good TPS, but mainly wanting any other problems that could cause this car to die or for the TPS to get a wrong reading.
Old Jan 7, 2008 | 01:06 PM
Rosko's Avatar
what happens when you plug just the TPS into the harness, and rotate it with your fingers? Can you see the full voltage range then?
also are you measuring 5 volts on the input wire with the tps plugged in or unplugged?
Old Jan 7, 2008 | 01:51 PM
JasonST's Avatar
Default Re: TPS problem (Rosko)
I had this problem when I was trying to put in a new tps for the first time and simply put it in. There's a certain way it goes in, as u twist it u should be able to feel a bit of resistance. So go back and make sure it's on and installed properly just to make sure.
Old Jan 8, 2008 | 05:05 AM
wstsydr's Avatar
Default Re: TPS problem (JasonST)
Yeah, when i put it in i could turn it, but it still wouldnt get me in the right voltage range, the closest voltages that i got to correct were the ones i listed, without turning it i got like .2 at idle and 2.3ish WOT and yes it does have 5v from the input wire with it grounded to the output
Old Jan 8, 2008 | 10:50 AM
JasonST's Avatar
I was trying o say that make sure u have the actual tps sensor in correctly. the first time I put a tps sensor I didn't know that you had o put it in a certain way than twist it to get it to read .5V at idle. I jus stuck it in and no matter where I turned it, i would onl go to abou half of the .5V. Make sure that when u put the sensor in that u can move it and then let go and it should spring back a bit.
Old Jan 8, 2008 | 11:30 AM
wstsydr's Avatar
Ahh, ok, sorry for the misunderstanding, i will give that a shot later today, hopefully it will work out right, do you think the problem i am having with the TPS would be the reason that it is just dieing like it is? I'm just really hoping that it is so i can get this thing back on the street.
Old Jan 8, 2008 | 08:02 PM
wstsydr's Avatar
Alright, that fixed it, just had to have it seated into the TB correctly, Thank you very much Jason, I do have another problem tho, but i am starting a new thread, come join in on the fun... https://honda-tech.com/zeropost?cmd=fshow&id=4
Danny Rogers
Mar 31, 2019 02:35 PM
danekmeier
Jan 16, 2010 07:59 AM
Rayog21
Aug 26, 2009 08:31 AM
kinkyintegra
Jan 8, 2007 01:56 PM
BoBo Racing
Dec 10, 2006 08:21 AM
