96 vtec ECU code
Old Jan 10, 2008 | 05:07 PM
vile10's Avatar
Default 96 vtec ECU code
anyone know the code for 96 vtec model? specifically 96
Old Jan 10, 2008 | 05:18 PM
Acidcrakker's Avatar
Default Re: 96 vtec ECU code (vile10)
96 is p13 I believe.
But its the year it went OBD2. You do have OBD 2 right?
Old Jan 10, 2008 | 05:21 PM
v4lu3s's Avatar
RTFM
http://www.slhondaparts.com
look up the part number
Old Jan 10, 2008 | 05:23 PM
Default Re: (v4lu3s)
What section is under? Im at that sight right now attempting to cofirm its a p13
Old Jan 10, 2008 | 06:30 PM
vile10's Avatar
yes, it's OBD II, but no immobilize
Old Jan 10, 2008 | 06:48 PM
vlang29's Avatar
Default Re: (vile10)
P13 is OBDI only. i believe the OBDII are P5M
Old Jan 10, 2008 | 06:53 PM
vlang29's Avatar
Default Re: (vlang29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">P13 is OBDI only. </TD></TR></TABLE>
i was wrong. i guess 96 OBD II are also p13, but with OBD II pinouts. P5M is for 97-01 OBD II
Old Jan 11, 2008 | 03:42 AM
Confusing. Honda Must have been hitting the bottal kinda hard that year<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">
i was wrong. i guess 96 OBD II are also p13, but with OBD II pinouts. P5M is for 97-01 OBD II</TD></TR></TABLE>
Old Jan 11, 2008 | 05:31 AM
vlang29's Avatar
Default Re: (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Confusing. Honda Must have been hitting the bottal kinda hard that year</TD></TR></TABLE>
amen
Old Jan 11, 2008 | 06:03 AM
mgags7's Avatar
Not really guys...they kept the same ecu for the same car 93-96 prelude vtec all came with p13s. 5th gens all had p5ms or p5ps
Old Jan 11, 2008 | 06:06 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">What section is under? Im at that sight right now attempting to cofirm its a p13</TD></TR></TABLE>
its in the electrical section, then look for pgm fi in that menu.
Old Jan 11, 2008 | 06:15 AM
vlang29's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Not really guys...they kept the same ecu for the same car 93-96 prelude vtec all came with p13s. 5th gens all had p5ms or p5ps</TD></TR></TABLE>
are you saying that a 96 OBDII P13 is the same thing as 92-95 OBDI P13?
Old Jan 11, 2008 | 07:39 AM
nautique196's Avatar
37820 P13 A12... i need one for my swap to pass emissions.
Old Jan 11, 2008 | 08:52 AM
gotjnco's Avatar
im not calling you a liar, but when I took out my p13 from my 93 vtec model to my friend's 96 vtec model, he couldnt use my p13 ecu, b/c the plugs wouldn't fit.
Old Jan 11, 2008 | 09:25 AM
SikB's Avatar
Default Re: (gotjnco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotjnco &raquo;</TD></TR><TR><TD CLASS="quote">
im not calling you a liar, but when I took out my p13 from my 93 vtec model to my friend's 96 vtec model, he couldnt use my p13 ecu, b/c the plugs wouldn't fit.</TD></TR></TABLE>
The plug wouldn't fit because it is OBD II. The name P13 or P5M has nothing to do with what version of OBD it is and everything to do with model, generation and sometimes, as in this case, trim level. Calling these ECUs P13, P28, P72 etc is entirely an aftermarket and tuner thing.
Old Jan 11, 2008 | 10:36 AM
mgags7's Avatar
I should have said same ecu code, of course the obd2 is different than the obd1
Old Jan 13, 2008 | 01:33 AM
vile10's Avatar
Default Re: (SikB)
that's beause OBD I has 2 rows of pins and OBD II has 3 rows of pins
Old Jan 13, 2008 | 06:54 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vile10 &raquo;</TD></TR><TR><TD CLASS="quote">that's beause OBD I has 2 rows of pins and OBD II has 3 rows of pins</TD></TR></TABLE>
....among other things, but yes
Old Jan 13, 2008 | 02:40 PM
vlang29's Avatar
so, out of curiosity, would a p5m work fine plugged into an OBD II 96?
Old Jan 13, 2008 | 07:25 PM
mgags7's Avatar
No
The p5(x) ecus have immobilizers, so it wouldn't really work.... and if it did, the injectors are smaller, so it wouldn't run right....
Type Wah
Nov 26, 2003 11:23 AM
Miz101
Oct 8, 2003 08:06 PM
shotty
Apr 16, 2003 05:13 PM
speedymon
Oct 1, 2002 02:26 PM
Stu
Aug 28, 2001 05:14 AM
