Odd Ignition Switch Drain Problem.
Old Jan 14, 2008 | 11:06 AM
AmauryR's Avatar
Default Odd Ignition Switch Drain Problem.
Hi, I'm having a wierd problem with my car since I owned it. First, I noticed the ignition key always felt a little warm to the touch (its pretty cold out, so that's defintely not normal). Sometimes, when I'd pull the key out it would beep like the key's still in (untill I bang the column). Now, something has been draining my battery. At first I thought it was a charging issue, replaced battery n alternator (both were bad anyways). I just had my battery checked out yesterday and it came out good (although drained). I checked it with a voltmeter, 14.2v running and 12v off, so that checks out as good. Got home last night, pulled the key out and the blower motor was still running?!? Nothing else though (that I could tell). Shut everything down, woke up this morning and the car was dead as a rock. I'm going to try and find a ignition switch and put one in (hope a 90-93 accord one will fit)... Any suggestions? I'll post up what I can find.
-l8r
Old Jan 14, 2008 | 11:56 AM
Jagan'92's Avatar
Default Re: Odd Ignition Switch Drain Problem. (AmauryR)
part numbers for the prelude and accord are different.
i think there are two connectors on the prelude wire bundle, whereas the accord switch has a single connector.
Old Jan 14, 2008 | 03:13 PM
AmauryR's Avatar
Default Re: Odd Ignition Switch Drain Problem. (Jagan'92)
thnx 4 the info. A friend of mine has a accord 5-speed one (90-93) @ his shop n said it has 2 connectors, a big brown one n a smaller grey one. I'll compare it to mine first n see what happens.
Old Jan 14, 2008 | 03:15 PM
Giant_Bean's Avatar
Where are you in CT, I'm a parts monkey, I might be able to find you a switch.
Old Jan 15, 2008 | 05:12 PM
AmauryR's Avatar
Default Re: Odd Ignition Switch Drain Problem. (Giant_Bean)
Hartford area, PM me if you have a switch for a 4g lude... thanks man.
bfc53005
Sep 15, 2012 03:13 PM
sweck
Sep 6, 2009 07:02 AM
sarkaztik
Oct 11, 2006 06:57 AM
JamesQ
Jun 2, 2005 02:19 PM
Tx92AccordExD
Jul 22, 2003 03:52 PM
