apexi v-afc controller
Old Feb 24, 2008 | 05:01 PM
xxervio's Avatar
Default apexi v-afc controller
i recenly purchased a 98 prelude type SH. it has an apexi vafc controller installed in it and i am trying to figure this thing out. anyone have knowledge of any settings or do i need to take it to a local tuner shop and have them tune it? it was bouncing from 1.5 rpm to 2k rpm but i managed to change he sensor numbers and now have it running at a flat 1k. but i am lost when it comes to changing the wide open throttle and narrow throttle or what settings are best. it is an older version of he vafc so i am having a hard time finding a manual on it.
thank you for any help you can provide.
Old Feb 24, 2008 | 08:29 PM
no1knows908's Avatar
Default Re: apexi v-afc controller (xxervio)
It's not a good idea to attempt to tune it without a wide band O2 sensor. Best thing to do is look at the ECU and hopefully the previous owner shelled out the extra money for a plug and play adapter harness. If he did use a P&P harness just unplug the VAFC till you can get a dyno tune. A lot of people on here might give it a , but might as well use it since it was free and already installed. Worst case scenario if its hardwired to the ECU I wouldn't recommend running it too hard till you can at least get someone experienced with it to check all your settings. As far as I/H/E, the VAFC in going to work fine.
Modified by no1knows908 at 1:48 AM 2/25/2008
Old Feb 24, 2008 | 10:37 PM
Speedra500's Avatar
Default Re: apexi v-afc controller (no1knows908)
for any series mods the VAFC is not a very good option. I'm not exactly sure what the options for SHs are these days, I believe the greddy Emanage is one though, which would be much better than the VAFC
Old Feb 25, 2008 | 04:15 AM
HondaKyle's Avatar
Default Re: apexi v-afc controller (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">for any series mods the VAFC is not a very good option. I'm not exactly sure what the options for SHs are these days, I believe the greddy Emanage is one though, which would be much better than the VAFC</TD></TR></TABLE> What if you have to need to tune the car on the spot? do you wanna carry a lap top around?
Old Feb 25, 2008 | 03:24 PM
xxervio's Avatar
Thank you for the advice, i will have to check out the ECU and see if there is an adapter and unplug it. If not i guess i will will run around taking it easy until i can get to the tuner shop.
Since i am not running turbo do i still need a wide band AF guage or will a normal AF gauge work??
Modified by xxervio at 4:44 PM 2/25/2008
Old Feb 25, 2008 | 05:59 PM
vlang29's Avatar
if your engine is not heavily modified, and you don't have a wideband to tune, leave all the fuel settings at "0"
here is the instruction manual
http://www.apexi-usa.com/pdfInstallation/48.pdf
Old Feb 25, 2008 | 06:01 PM
vlang29's Avatar
Default Re: apexi v-afc controller (vlang29)
if you have idle problems with all fuel settings at 0, you have a problem elsewhere, do NOT try to fix it with the afc..
check this link: https://honda-tech.com/zerothread?id=1979500
B18C7
Apr 21, 2003 12:20 PM
delslow1
11
Mar 27, 2003 08:35 AM
.Ryan
Jan 6, 2003 07:55 PM
Civichatch2k
Sep 30, 2002 05:44 PM
ryu12341
Aug 11, 2002 09:32 PM
