Low Compression
Old Feb 25, 2008 | 08:56 PM
Drewmoney82's Avatar
Default Low Compression.......HELP PLEASE
So my friend who is a mechanic ran a compression test on my Prelude, He said i had around 125 to 140 PSI. So apparently i will be investing in some new piston rings. I was wondering and since i am a Newbie, what else should i look into replacing while i am getting this done? The Prelude is an SH with around 103.5k on it. Any advice would be great, i am in some need of it!! THanks
Modified by Drewmoney82 at 11:21 PM 2/25/2008
Old Feb 26, 2008 | 12:23 AM
Acidcrakker's Avatar
Default Re: Low Compression.......HELP PLEASE (Drewmoney82)
Some new pistons and have the block re-bored. Might as well get the head port and polished, dont forget about a tuning system
No that is not going to be able to fix the issue. But since you have to put new rings on the pistons might as well go all out since your going to be pulling the whole motor.
Read inbetween the lines, to the poster under me.
Modified by Acidcrakker at 12:32 PM 2/26/2008
Old Feb 26, 2008 | 07:06 AM
xxmastermindxx's Avatar
Default Re: Low Compression.......HELP PLEASE (Acidcrakker)
P & P and a tuning system to fix low comp? ok.....
well, since you have low compression, if we rule out a head or head gasket issue, then yes your rings probably need replacing. your bores will need to be checked to see if they need to be re-bored, and if so, yes you will need new pistons and rings.
but on the off chance that a fresh hone will keep you in spec (unlikely though), all you'd need is new rings.
P & P isn't necessary for fixing what you asked, but if you get oversize pistons and bigger bores, a tune would help.
Old Feb 26, 2008 | 07:26 AM
Does anyone have a link to where i can find a good set of pistons? This is going to cost me a boat load of money!! Luckly i might be able to save some on labor with my friend doing the work. Thanks for the advice so far!! Keep it coming!
Old Feb 26, 2008 | 08:13 AM
v4lu3s's Avatar
RTFM
while its apart I would put new bearings in...might as well rebuild the bottom end since most of the labor is done already. check out the mahle gold series pistons OR look for some type-s pistons.
b18bEKcoupe
Mar 4, 2007 06:33 PM
GSR4U2NV
Jan 24, 2006 05:27 PM
94gsr18kid
10
Jan 25, 2005 05:35 PM
94gsr18kid
Jan 25, 2005 09:02 AM
