Clutch
Old Feb 18, 2008 | 01:02 PM
spiderseth's Avatar
Default Clutch
Well I jump in the lude to go play poker and guess what it starts. I try and shift gears a no go. WTF ok so I turn the car off and put it in gear and try to start it wont start. So it starts when not in gear but wont go in gear when the cars on, and wont start if the cars already in gear. I'm gonna guess that I need a new clutch master and slave cylinders, but a confirmation would help. I just put a new clutch in about 40k ago but it showed no signs of grinding or resistance to go in gear due to worn out clutch.
Old Feb 18, 2008 | 07:27 PM
AndyD's Avatar
Default Re: Clutch (spiderseth)
Sounds like your clutch disk is warped. Happened to me. I couldn't shift gears when the car was running....but it would shift fine when the car was off.
If I were to bet....I would say one of the springs popped out of your clutch disk.
What kind of clutch did you have installed?
Old Feb 18, 2008 | 11:06 PM
teg969's Avatar
if blew a clutch disk racing with my teg back in the day...the spring flew out...but i could still press on the clutch and get the thing going...but it grinded like a mother F*** so if the spring was loose...when you press on the clutch you can defenitly hear it !!...if there is no sound when you press on it...might be something else...check to see that the forks on your tranny arent messed up...maybe thats the problem...cuz if you cant put it in gear while the car is offf....?/??? im really not sure what the problem could be...
Old Feb 18, 2008 | 11:16 PM
spiderseth's Avatar
Default Re: (teg969)
When I had the new cluch put in its bc my tranny went out and it was still under warranty. So Honda did it I really don't know what ever factory parts Honda uses for clutches.
Old Feb 21, 2008 | 10:58 AM
boostedh22lude1's Avatar
Default Re: (spiderseth)
do u have a pedal, is it firm or go to the floor?
Old Mar 2, 2008 | 01:35 PM
spiderseth's Avatar
Default Re: (boostedh22lude1)
well update is i installed both the master and slave clutch cylinders and bled it and the pedal still goes to the floor and dont come back up with no reistance at all. WTF if it is my clutch Honda clutches suck *****.
Old Mar 2, 2008 | 01:54 PM
dagle's Avatar
u didnt bleed it enough.. pump it another 2000 times. literally.
Old Mar 2, 2008 | 02:09 PM
spiderseth's Avatar
Default Re: (dagle)
aight i think im gonna buy one of those pump type and just hook it up to the bleeder valve. Yeah i only did it like 30 times 2k sounds like an hour. Damn it took me an hour just to ge that stupid cotter pin out of the pedal. Thanks man Ill try that tommorrow.
DulinDragons
Sep 29, 2015 01:09 AM
SonicRacing
Feb 26, 2006 01:54 PM
dexy
Jan 11, 2005 09:53 AM
93civcx
Jun 18, 2004 06:25 AM
This One
Mar 21, 2003 05:23 AM
