lacking power
Old Mar 2, 2008 | 11:52 AM
mikeaitken's Avatar
Default lacking power
My car suddenly staretd to lack power and doesnt pull good when vtec kicks, doesnt even sound as oud either. Thought id replace my clutch and flywheel, but still no luck??? im so confused and dnt know whast going on. i got good compression. and oil and oil pressure. someone said it could be your cat? cuz mine is old. could that be lacking all this power and holding me back? please help, ive been all over the place. thanks!
Old Mar 2, 2008 | 11:56 AM
Hawkze_2.3's Avatar
Default Re: lacking power (mikeaitken)
Yeah, could be the cat, could be a failed timing belt tensioner, etc... No check engine lights?
Old Mar 2, 2008 | 11:58 AM
Acidcrakker's Avatar
Sounds like something isnt working right
It could be your cat if its just clogged.
Or mabey clogged fuel injectors
Old Mar 2, 2008 | 12:01 PM
autoluder's Avatar
Sounds like your secondary runners are not opening up or working properly, which is why your not getting increased sound.
Modified by autoluder at 10:21 PM 3/2/2008
Old Mar 2, 2008 | 12:04 PM
Hawkze_2.3's Avatar
Default Re: lacking power (autoluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoluder &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your secondary runners are not opening up or working properly, which is why your not getting increased sound and its not triggering your vtec solenoid. </TD></TR></TABLE>
What do the secondaries have to do with the VTEC solenoid?
Old Mar 2, 2008 | 12:07 PM
IrregularRice's Avatar
Check for a Vaccum leak. My buddies car did the same thing.
Old Mar 2, 2008 | 01:34 PM
98vtec's Avatar
moderator emeritus
you sure the lack of power is not a figment of your imagination?
Old Mar 2, 2008 | 02:29 PM
Default Re: lacking power (98vtec)
Which Bellmawr areyou in? Is it the one near Camden or the One Near Asbury Park?
Old Mar 4, 2008 | 01:01 PM
mikeaitken's Avatar
Default Re: lacking power (Acidcrakker)
near camden. and nah not no figment of my imagination. My car used to pull so good, and now its lacking so bad.
Old Mar 4, 2008 | 01:27 PM
TPS?
Old Mar 8, 2008 | 07:34 AM
mikeaitken's Avatar
Its fine. checked my oil. temp and pressure. injectors. and i guess im gnna try to mess with my exhaust. to see if it could be that. ill let yah all know. i appreciate it
Old Mar 8, 2008 | 07:38 AM
If you want, we could meet up sometime, and I could take a look at it if you want. Im right in Barrington.
nate24740
Honda Civic (2001 - 2005)
12
Nov 21, 2007 05:13 PM
07GPWS2K
11
Jun 1, 2007 08:15 AM
jxkim89
Feb 12, 2007 08:55 PM
dpharand
Apr 15, 2005 12:51 AM
accord03coupe
Oct 14, 2004 03:45 PM
