I need help again.......
Old Mar 2, 2008 | 11:20 AM
IrregularRice's Avatar
Default I need help again.......
Ok my steering wheel has been installed now my "SRS" light stays on??? How do i Make it stop?
Old Mar 2, 2008 | 11:26 AM
Hawkze_2.3's Avatar
Default Re: I need help again....... (IrregularRice)
SRS is your airbags....sounds like you need to make sure all the connectors are plugged in. Though I am assuming you have installed a stock steering wheel because there's no details in here...
Old Mar 2, 2008 | 11:38 AM
Acidcrakker's Avatar
Default Re: I need help again....... (Hawkze_2.3)
Im assuming he installed an aftermarket steering wheel. One that didnt have an srs delete on the Hub.
Old Mar 2, 2008 | 11:40 AM
Sorry about that. OK, I have a 96 Prelude. I just installed a Grant GT steering wheel using a Grant 91' prelude adapter kit. so there are no connections. I tried to solve the problem by pulling the fuse....... SRS light still on. so i'm assuming there is a couple wires somewhere that have to have connection for the light to go out.
Old Mar 2, 2008 | 11:43 AM
Hawkze_2.3's Avatar
Easiest thing is to just pull the SRS bulb out. I'm sure you could connect the wires together to get the light to go off if you wanted to though.
jr408
Mar 6, 2008 01:28 PM
erck
Jun 8, 2007 07:34 PM
Rene M
Oct 11, 2006 02:43 PM
Marauder
Apr 11, 2003 03:26 PM
