Mild overheating problem! Please help
Old Feb 28, 2008 | 09:01 PM
JMWood's Avatar
Default Mild overheating problem! Please help
Alright so my 95 Prelude 2.3 is overheating.
the funny part about it, is it used to take 2 - 3 hours of driving for it to do so. sometimes even up to 6 hours it would be fine.
it never truly overheats it only goes to the middle mark between optimum and the red.
i simply throw it in neutral and turn the heat on full and it goes back down and stays that way.
Any ideas?
Old Feb 28, 2008 | 09:57 PM
dagle's Avatar
Default Re: Mild overheating problem! Please help (JMWood)
if it's getting worse progressively.. ill bet that your coolant level is lower than before and that you have a very slow leak or you're due for a coolant flush..
Old Feb 28, 2008 | 10:25 PM
JMWood's Avatar
Default Re: Mild overheating problem! Please help (dagle)
I'm wondering if it has anything to do with the thermostat
Old Feb 28, 2008 | 10:29 PM
dagle's Avatar
check all of those things... cheap fixes.. but however, if your car overheats too much itll result in a blown headgasket.. which isn't a cheap fix.
civic89si666
14
Feb 9, 2011 11:02 AM
HuGEN
Jun 30, 2007 09:49 PM
rdaggett
Aug 11, 2004 12:48 PM
mightyone
Jun 28, 2003 01:26 PM
Dodger2940
Jun 17, 2002 11:26 PM
