shifting problem
Old Feb 24, 2008 | 02:51 PM
Bottledh22's Avatar
Default shifting problem
car is an 01 sh. i got in it took off everything was ok then after bout 5 to 10 minutes it started not wanting to go into gear very easily. the higher rpm the harder it gets. it feels like the clutch isnt fully dissengaging. i tried bleedin the clutch. didnt work....
Old Feb 24, 2008 | 06:11 PM
quaa's Avatar
Default Re: shifting problem (Bottledh22)
simular thing happened to me. took it to the stealership and they rebuilt the tranny for free under warranty
Old Feb 28, 2008 | 05:06 PM
Bottledh22's Avatar
the car will go into gear easier at lower rpm's and at higher rpms it gets harder to get it into gear. it also goes in to first gear fine when i go to take off. can any body give me a little advice?
Old Feb 28, 2008 | 05:27 PM
h23prelude's Avatar
ill bet your syncros are starting to wear down, first gear has a double syncro thats why first feels ok, it could be a bent shifter fork in the transmission? is there ANY other problems, noises, fluid condition issues, idle problems, that are apparent? a little more info could help
did this happen all the sudden, or a gradual problem?
does it happen in all the gears except first?
how many miles on the transmission? was it recently rebuilt?
Modified by h23prelude at 9:09 PM 2/29/2008
Old Feb 28, 2008 | 05:56 PM
JDM R Cooker's Avatar
Default Re: (h23prelude)
hey, I thought Im the only one with that problem. I had dat problem also. Is there a solution? Im thinking about the short shifter from pspec tunning.
Old Feb 29, 2008 | 03:17 PM
Bottledh22's Avatar
the car has 82k mi. and yes it happened all of a sudden. and no the tranny has not been rebuilt.
i had one person tell me that they had a similar problem and the pressure plate was not fully disengaging. thats what their problem ended up bein.
its stressin me out . i just wantt to get it figured out.
Old Feb 29, 2008 | 08:13 PM
h23prelude's Avatar
Default Re: (Bottledh22)
well i'm going to assume that it is the stock clutch. sounds like the pressure plate and or the clutch disc took a crap. if it happened all of the sudden its probably not going to be a syncro problem. so i would defiantly check out your clutch, its most likely the problem. good luck!
Old Feb 29, 2008 | 08:39 PM
dreamreaperx's Avatar
i'm having somewhat of a similar problem...car is a 2000 with about 108,000 on the tranny...2nd and 3rd are having grinds every now and then and 5th is popping out of gear on it's own. running a fidanza stage 3 clutch and fidanza flywheel...any advice?
Old Mar 1, 2008 | 06:36 AM
vlang29's Avatar
Default Re: (dreamreaperx)
if you have grinds on only certain gears, it is probably synchro's.
If every gear goes in hard, chances are it's clutch related
Old Mar 1, 2008 | 01:03 PM
Bottledh22's Avatar
thanks, i appreciate the help alot!!!!!!!!!!
OneFire
Jul 26, 2009 04:56 AM
Eddie99
Honda S2000
24
Oct 16, 2007 01:22 PM
Villenurve
Oct 12, 2007 09:58 AM
D15VTEC
Mar 19, 2003 05:17 AM
is3oo
Jun 6, 2002 10:10 PM
