axle installation
Old May 1, 2008 | 01:35 PM
paniaguae640's Avatar
Default axle installation
Looked around the FAQ and i found nothing on this. Never replaced axles before I am going to attempt this. I have a 94 Prelude Si and wanted to know what I had to do and how hard it will be to change. And also if I have to change my tranny fluid, my tranny fluid is less than 100 miles.
Old May 1, 2008 | 01:48 PM
95greenlude's Avatar
Default Re: axle installation (paniaguae640)
get a helms manual....
it will guide you through everything about your car.
http://www.helminc.com/helm/homepage.asp?r=
Old May 1, 2008 | 02:00 PM
dagle's Avatar
Default Re: axle installation (95greenlude)
lol i hate doing axles, cuz the axle nut is super tight..
Old May 1, 2008 | 04:33 PM
IEnjoiHondaBALLS's Avatar
Default Re: axle installation (dagle)
the axle nut turns counterclock wise right to loosin? im doing mine at the moment (front right) and it is not budging damn breakerbar lol
Old May 1, 2008 | 04:34 PM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">Looked around the FAQ and i found nothing on this. Never replaced axles before I am going to attempt this. I have a 94 Prelude Si and wanted to know what I had to do and how hard it will be to change. And also if I have to change my tranny fluid, my tranny fluid is less than 100 miles.</TD></TR></TABLE>
Other than the axle nut can be a little tough to remove do to its tightness and the lower ball joint, swapping an axle is relatively easy. I would say its about 3 on a scale of 10. Also you will not have to change the tranny fluid when swapping an axle
Old May 1, 2008 | 05:52 PM
snobordboy's Avatar
Moderator
Yup clockwise on those axle nuts and they are super tight, but a good 1/2 inch impact will zing them right off.
For an overall guide, search for the cltuch how-to by "Behan" it shows all the steps very well!
Old May 1, 2008 | 06:05 PM
dagle's Avatar
Default Re: (snobordboi)
i used a breaker bar and jumped/stomped on it for a good 5 minutes before it finally budged.. (and someone was in the car mashing the brakes down)
nonvteclude
Aug 7, 2006 08:45 PM
powerofdreams8
Jun 13, 2006 07:30 AM
hypeR speed
Apr 3, 2006 12:09 PM
14bcoupe
Jul 25, 2005 05:24 PM
