ECU
Old Apr 27, 2008 | 06:48 PM
nudeinthelude's Avatar
Default ECU
I have recently been doing alot of researching about ecus, and I need help. I have a 92 Honda Prelude with a h22a VTECH motor. My ecu is a p13, but I have seen some post about being able to use a p28. Do I need wiring convertorsor anything to use one, and what is the difference between them???
Old Apr 27, 2008 | 08:23 PM
dagle's Avatar
Default Re: ECU (nudeinthelude)
a CHIPPED P28 is a fully tunable ECU, everything can be changed for your needs, but that is not the cheapest route. For your needs, I would suggest for you to keep your P13.
Old Apr 28, 2008 | 11:12 AM
brad225's Avatar
i had the p 13 ecu for about a week u should get the p28 it is alot better than the p 13 u can chip it an get it tunned ur h22 will run like a beast but u might want to change to bigger fuel injectors to be safe like i did good luck
Old Apr 28, 2008 | 11:40 AM
98vtec's Avatar
moderator emeritus
Default Re: ECU (brad225)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brad225 &raquo;</TD></TR><TR><TD CLASS="quote">i had the p 13 ecu for about a week u should get the p28 it is alot better than the p 13 u can chip it an get it tunned ur h22 will run like a beast but u might want to change to bigger fuel injectors to be safe like i did good luck </TD></TR></TABLE>
why did you get bigger injectors?
ONLY get a p28 if you are going to get it tuned. If you plan on just buying a chipped ecu and then putting it in without getting actual tuning done then dont waste your money.
the p13 is the stock ecu and is what should be used on a stock motor.
EG-SIXV-TEC
Engine Management and Tuning
Jan 3, 2014 07:57 PM
Nicram
33
Nov 11, 2005 04:07 PM
havalilsi
Oct 4, 2004 11:57 AM
gookspeed
May 15, 2004 02:58 AM
Jasper_db1
Feb 5, 2004 04:18 PM
