Grinding
Old Apr 22, 2008 | 09:00 PM
paniaguae640's Avatar
Default Grinding
I have a 94 Honda Prelude Si. The thing is when I'm driving and i shift the gears grind, and no i'm not new to manual. When you even do it perfect the gears grind, for example
i shift from 3 to 4 and it grinds for 1 sec and then it goes away. Does anyone have any ideas on what could be the problem?
Old Apr 22, 2008 | 09:12 PM
bump
Old Apr 22, 2008 | 09:57 PM
iLood's Avatar
Default Re: (paniaguae640)
Syncro's are gonzo or you have no tranny fluid. Sync's are notorious for grinding in h23 trannnys, esp 3rd gear. Start with the little, less cost effective things to do. I ran half GM Syncromesh and half of the newest Honda MTF. It helps, but if your tranny/sync's are bad then it won't cure the problem, it'll just put a temporary band aid on things whilst curing a little bit of the grind.
boosted_EM1
12
Feb 7, 2008 12:58 PM
t-town_ep
10
Apr 1, 2007 12:41 PM
f150harleytruck7
Jul 13, 2005 04:04 AM
ServiceAdvisor
Jan 27, 2005 05:12 PM
ncVTEC1313
Oct 14, 2003 04:52 AM
