Same partial throttle issues...
Old Apr 24, 2008 | 08:20 AM
lsjon's Avatar
Default Same partial throttle issues...
Still having 1-2krpm throttle hesitation.and when i say hesitation its when u slowly feed it throttle it feels alittle like its hitting a rev limiter until u feed it more and more throttle. but once u hit 2k theirs no more hesitation.
cel codes=iacv,egr.
engine=f20b dohc vtec
ecu=p13
ive replaced the iacv with a brand spanking new oem valve, checked the wires, everything is fine.
egr code is showing because its blocked off.
checked the tps=fine
checked the timing=fine
sprayed massive brake clean=no vacume leaks from manifold.
checked all vacume lines=all fine
i also get rough engagement when letting off the throttle and getting back on the throttle at any rpm and speed.
im completely at a lost, possibly just bad ecu? the car is also running a vafc2, i had a buddy check it over and he said everything in the vafc2 looks fine.
Old Apr 24, 2008 | 09:12 PM
Arsenal's Avatar
Default Re: Same partial throttle issues... (lsjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsjon &raquo;</TD></TR><TR><TD CLASS="quote">running a vafc2, i had a buddy check it over and he said everything in the vafc2 looks fine.</TD></TR></TABLE>
Think you have answered your own question
jksmith
Feb 19, 2009 09:39 AM
boostcrx89
Jan 6, 2008 07:54 PM
Pr0ject93hb
Nov 27, 2006 01:15 PM
handa
Jan 1, 2005 01:52 AM
AndrewCJ
Jun 5, 2003 08:08 AM
