Help with speed sensor problem
Old May 5, 2008 | 10:24 PM
pazookie's Avatar
Default Help with speed sensor problem
ok i have a 1989 prelude 2.0 SI Fuel Injected.. i had some problems with my speedometer and odometer not working, so i remove the speed sensor housing from the transmission and upon reinstalling it i overtightened the bolt that secures it to the tranny and it broke off in the threading..about 1/4 of the bolt was left in my socket..yes i know im an idiot...it just wasnt getting tight at all so i kept spinning it and pop...so any ideas how to get myself out of this mess? all i could think of is drilling a small hole and backing out the bolt but its such a tight area on this gen of prelude that drilling is pretty much impossible.. i had a hard enough time getting that speed meter out..any help would be appreciated..
Old May 5, 2008 | 10:28 PM
Hawkze_2.3's Avatar
Default Re: Help with speed sensor problem (pazookie)
If some of the bolt is still sticking out you can just use a bolt extractor...should be relatively easy.
Old May 5, 2008 | 10:32 PM
pazookie's Avatar
Default Re: Help with speed sensor problem (Hawkze_2.3)
no not much, maybe a mm..enough to feel slightly if i run my finger over the hole..
Old May 5, 2008 | 10:42 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pazookie &raquo;</TD></TR><TR><TD CLASS="quote">no not much, maybe a mm..enough to feel slightly if i run my finger over the hole..</TD></TR></TABLE>
Ok, well that's not enough. The only thing I can think of is finding some way to drill a hole in that bolt and use a bolt extractor, or if you can somehow cut a slit in it you could use a flathead. Maybe remove the passenger side wheel for better access...
Old May 5, 2008 | 10:54 PM
pazookie's Avatar
the flathead sounds like the best idea as i dont see a drill getting straight onto that thing any time soon lol...maybe i can cut at it with a razor for about a few days ;-)...remove the wheel you say...never thought of that..ill have to look into that..
Old May 5, 2008 | 11:44 PM
Hawkze_2.3's Avatar
Yeah, if you can remove the wheel and splash guard you should be able to get a Dremel or something in there to cut a little slit in the bolt remains...
Old May 6, 2008 | 11:56 AM
pazookie's Avatar
ok couple more questions..when i removed it, there was a type of silicone gasket (from a tube) that i peeled off..should i replace it when i get this all sorted out and reinstall the vss? and second..is there a temporary solution i can use to keep the vss in the tranny or plug the hole in the tranny and clamp the hoses going into the vss so the vehicle can be driven?
Old May 6, 2008 | 12:28 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pazookie &raquo;</TD></TR><TR><TD CLASS="quote">ok couple more questions..when i removed it, there was a type of silicone gasket (from a tube) that i peeled off..should i replace it when i get this all sorted out and reinstall the vss? and second..is there a temporary solution i can use to keep the vss in the tranny or plug the hole in the tranny and clamp the hoses going into the vss so the vehicle can be driven? </TD></TR></TABLE>
You can get liquid gasket anywhere to replace that gasket.
I would not try to mess with those lines going to the VSS, that's your power steering fluid and if you undo those all the fluid is probably going to come out and then you'll have clean up and refill the whole system....too much trouble. I would try to find a way to zip-tie that thing in place real good.
IA95civicDX
May 15, 2009 10:29 PM
Honda_ThuGZ
10
Mar 31, 2008 08:25 PM
93sihatchy
11
May 21, 2007 11:30 PM
GarageAlchemist
19
Aug 18, 2006 11:23 AM
