Pulley Help.
Old May 7, 2008 | 05:02 AM
sh-izzle's Avatar
Default Pulley Help.
I cannot remove the pulley's from neither my h22 or f22 water pump's. This is my final step to completing my g22 and its becoming annoying. I have tried three different pullers but no luck. Any suggestions, I'm assuming a machine shop could do it if I could find one around here. Thanks
Old May 7, 2008 | 11:45 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Pulley Help. (sh-izzle)
I dont belive the pullies are removable. You replace the pump as a whole...
Old May 7, 2008 | 12:10 PM
sh-izzle's Avatar
Default Re: Pulley Help. (DCFIVER)
take a pulley puller....
place the center punch on the main cneter piece and slowly pull the outside t-belt gear off the water pump....do the same for both of you pumps...being the h22/f22 you can use a shitty h22 waterpump so they are very easy to come by cause all you using is the gear...not the bearings and such...so just make sure you have a good f22 water pump and youll be set.
From prelittlelude's g22 build. It has a pic but it wont load up and I followed what they describe but no luck.
ACCORDingly94
Engine Machining & Assembly
Jul 27, 2015 12:55 AM
KurtPierce024
Jan 12, 2013 02:08 PM
monster152
Oct 18, 2011 03:23 PM
accordm3
Apr 15, 2003 09:57 AM
