CEL Code 145 : help
Old Jun 3, 2008 | 06:12 PM
brandobot89's Avatar
Default CEL Code 145 : help
After removing my cruise control, I plugged two vacuum hoses up with those vacuum caps. A few days later, a CEL comes on for code 145. I tried connecting a hose to both sides because the mechanic told me the the holes needed some air but it gives me a bouncing idle.
Here's a picture, the two holes that were plugged are capped in white. I removed the cruise control. The car is a 5th gen. Does this in any way affect my car in a negative affect?
Old Jun 3, 2008 | 08:36 PM
Acidcrakker's Avatar
Default Re: CEL Code 145 : help (brandobot89)
I forget what the name of that pipe is, but you need it back on there. Its not even related to the crusie control.
Old Jun 3, 2008 | 08:46 PM
i put it back in and plugged the electrical connection back also. I ran like this for a week with no cel, can there be any negative affect from driving like that?
Old Jun 3, 2008 | 08:47 PM
Yeah a vaccum leak.
Dont forget to reset your ECU once all your cels are cleared
Old Jun 3, 2008 | 09:10 PM
Default Re: CEL Code 145 : help (Acidcrakker)
thanks!
Old Jun 4, 2008 | 07:34 PM
mouab18c1's Avatar
do all obd2 cars have the same code numbers? or are they different from integras? im tryn to look for a list of codes for my buddys prelude...any help would be great..thanks in advance
Old Jun 6, 2008 | 09:12 PM
Default Re: CEL Code 145 : help (mouab18c1)
anyone know where the 3 nipples are suppose to connect to ontop of the throttle body? (the blue caps)
Old Jun 6, 2008 | 09:22 PM
They would most likely, plug into the Map sensor on the wall. And whatever else. There should be a diagram of the vaccum chart under your hood
Old Jun 7, 2008 | 02:39 PM
hmm. my vaccum charts are gone, i have a different hood.
Old Jun 7, 2008 | 03:14 PM
Go to hondahookup.com
They have PDF files you can download.
Its the helms you down load. Save yourself 75 bucks.
Darkane
Jun 18, 2008 07:21 AM
robunicu
Feb 22, 2007 07:47 AM
esca
Oct 14, 2004 06:34 PM
TTWS6.
Aug 26, 2003 06:51 AM
