What Altenator belt for H22 SWAP with NO AC/POWERSTEERING
im doing an H22 swap into my EG and im almost done. But i can't find a Altenator belt anywhere. Im not running AC or Power steering.i have gone back and forth to advance and autozone and they dont have what i need. Anyone know which belt to use, where i can get it, or a part number? Please help!
Re: What Altenator belt for H22 SWAP with NO AC/POWERSTEERING (Silvertc)
measure the diamater (in mm)of both pulleys, divide that # by two, then add 2x the distance from crank pulley bolt to alternator belt. This will give the approximate length of the belt needed.
Then check if it's 4 or 5 rib.
Done.
If they can't find you the right belt with that information, go to a different store that knows what they are talking about
Done.
i just took one of the old belts and cut it down until it would wrap around snug. i then took that to the autoparts store and had them match one up. id give you the part # if i were home with the car.
Ef4doorwagon
06-15-2014 06:15 PM
Silvertc
06-18-2008 02:02 PM
ozzyman
09-17-2003 07:00 PM
