How does this work?
Old Jun 2, 2008 | 10:44 AM
pkolaboy's Avatar
Default How does this work?
This was posted on one of my threads and i do not understand what it means...
"dont forget to use the dizzy/external coil from your h23, unless you are planning on running the internal coil h22 one..."
Old Jun 2, 2008 | 12:23 PM
Saosinx's Avatar
Default Re: How does this work? (pkolaboy)
usdm coils are external. the jdm is internal. if you are swapping a jdm h22a, you will more than likely just use your dizzy (if you have an h23). just fab up a bracket to mount the coil.
Old Jun 2, 2008 | 03:41 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkolaboy &raquo;</TD></TR><TR><TD CLASS="quote">This was posted on one of my threads and i do not understand what it means...
"dont forget to use the dizzy/external coil from your h23, unless you are planning on running the internal coil h22 one..." </TD></TR></TABLE>
Internal coil distributor: ignition coil is smaller and mounted inside the distributor cap. It does exactly the same thing as any other coil, just a different setup
External coil distributor: distributor cap is empty and the actual coil is a separate unit mounted on the engine or engine bay somewhere. You have to have another ignition cable to go from the coil to the distributor cap with this setup.
Old Jun 2, 2008 | 09:14 PM
pkolaboy's Avatar
Default Re: How does this work? (Hawkze_2.3)
yea that cleared up alot! so i can just switch the dizzys right out orrrrr?
Old Jun 2, 2008 | 09:15 PM
pkolaboy's Avatar
bump
Old Jun 2, 2008 | 09:17 PM
Hawkze_2.3's Avatar
Hahaha, you waited 1 minute to bump the thread
You can swap the distributors out, you just have to use the coil that goes with each one.
Jhill_9202
Nov 6, 2005 08:41 PM
88ED8
Mar 23, 2005 09:12 PM
ophdehEEzY
Mar 8, 2003 10:06 PM
servion
Jun 20, 2002 08:59 AM
