Overheating problem
Old Jun 3, 2008 | 06:25 PM
eric416's Avatar
Default Overheating problem
The temp gauge has been going above normal but the fan doesn't come on. It usually only happened at idle and goes back to normal when i start to drive again but now it just went above normal while I was driving. I jumped the fan and I know that works. What else should I check?
Old Jun 3, 2008 | 11:11 PM
gstrudler's Avatar
Default Re: Overheating problem (eric416)
Where did you jump the fan? It could be either the fan switch or fan relay if you know the fan itself is working.
Old Jun 4, 2008 | 03:12 PM
eric416's Avatar
Default Re: Overheating problem (gstrudler)
it was by a plug near the thermostat if i remember correctly
Old Jun 4, 2008 | 05:05 PM
prelude0311's Avatar
My kar is doin the same thing, i bout a new relay but that wasnt the problem. Same thing with me. at Idle it overheats. when i drive normal. when i drive but get stuck in traffic and im moving slow it over heats. then when i shut it off the fan will kick on for bout 5 min. so I'm lost as ****. i'm just gonna put a racing koolant system in it.
Old Jun 4, 2008 | 07:08 PM
MUlrich07's Avatar
prelude0311, try adding coolant, maybe thermostat change... mine did the same, got a new thermostat and it worked GREAT.
im not too fond of jumping fans and such.. so i can't really help you out Eric
Old Jun 5, 2008 | 11:29 AM
wusdadeal123's Avatar
Default Re: (MUlrich07)
I am having the exact same problem with mine, but i have also noticed when im sitting in traffic and my car is over heating i can put it in neutral and give it about 4 rpms it will cool down. I am going to change my thermostat and add some coolant today and see what happens. If anyone else has any other suggestions please let me know.
Old Jun 5, 2008 | 12:54 PM
eric416's Avatar
Default Re: (wusdadeal123)
My radiator is also rotting out, its 5 years old so that might have something to do with it. I just bought a godspeed aluminum radiator on ebay so after i get it I'm going to put that in and also change the fan switch and thermostat and see what happens.
Old Jun 7, 2008 | 10:42 PM
Default Re: (eric416)
when i also go slow in traffic it over heats. like under 20mph It has a new thermostat, but my fan is not kickin on util after i shut my kar off. which is probably the fan switch, and also my radiator hose on the top of the radiator to the block swells up like a son of a bitch. and i just switched out the coolant. thinkin just bout puttin a new radiator in.
Old Jun 11, 2008 | 08:03 PM
redline7's Avatar
Default Re: (prelude0311)
u guys are all having the same problem...its the fan switch that sits in the thermostat housing. If u jump that plug and the fans come on then its most likely the switch. I tested my car one day and saw that the fans usually come on like every 2 min. at idle.
$amGD3
Jul 26, 2010 09:24 AM
aasaa666
May 31, 2010 07:15 AM
omgwtfbbq
12
Sep 24, 2009 06:22 PM
rextec
21
May 17, 2006 05:43 PM
z6honda
30
Feb 18, 2006 09:07 AM
