won't run
Old May 26, 2008 | 09:27 PM
krayzieboi213's Avatar
Default won't run
i don't know a lot about cars yet, i'm still learining quite a bit. i just rebuilt my h23vtec and it won't stay running. it fires up but runs very rough. and it only runs if i open the throttle some. as soon as i let off the gas it dies right away. does anyone have any suggestions on what may be the problem?... or any trouble shooting tips i can do?... thanks for any help
Old May 26, 2008 | 09:48 PM
Default Re: won't run (krayzieboi213)
after doing a little more reading i realized one thing i did wrong. i don't think i set my balance shafts right. if they're to far out of whack could that keep the motor from running?... how do i set them to the correct positions?
Old May 27, 2008 | 02:23 PM
nobody has any clue if there is a correct position for the balance shafts?
Old May 27, 2008 | 03:45 PM
Acidcrakker's Avatar
Title your threads better.
Check your ignition and timing.
If balance shafts are out of wack, the car would just run ruff.
Old May 27, 2008 | 03:48 PM
Default Re: won't run (Acidcrakker)
ok thank you. the thread is named what it is cause i couldn't get it to run. i read about the balance shafts and realized that i didn't set them right. thats why i asked about them. and it is running very rough when its running.
Old May 27, 2008 | 09:46 PM
Fongman's Avatar
when you say rebuilt, what did you do to it. you always remember, your car will not run if you have no gas, spark, and compression. if you are missing one it will not run and may act up? your car sounds like its running on 3 cylinder and not all 4 cylinder. the 1st thing that i would do is check for timing on the dizz and the mark on the crankshaft.
blackeg
Engine Management and Tuning
17
Dec 1, 2014 04:53 PM
Dontoh
34
Aug 1, 2011 04:16 AM
gt35rSI
Nov 15, 2007 01:47 PM
B18B EK
Jun 19, 2005 05:41 PM
VTgringo
Aug 18, 2003 06:50 AM
