SOMEBODY HELP PLEASE!
Old Jun 6, 2008 | 11:33 PM
89pre2.0si's Avatar
Default SOMEBODY HELP PLEASE!
I have a 89 prelude and I don't know what the problem is with it. It was fine all winter but now it got warm and it has had alot of trouble starting. Also having some trouble firing after stopping at stop signs and such, I thought it might be the plugs and wires because I hadn't changed them yet since I bought it. So I changed them and went to start it...it took me 2 hours to get it to start! It just cranks and cranks but won't fire. I noticed that when the check engine light is on, it does not fire, and when the check engine light is off, its about 50%. I'm more of an expert on older american cars and not so much the foreigners. Please help me, I'm so desperate and have no clue.
Old Jun 7, 2008 | 06:46 AM
Jagan'92's Avatar
Default Re: SOMEBODY HELP PLEASE! (89pre2.0si)
i'm not sure if the third gens. have the same problem with the main relay that the fourth gens. do - but that sounds like it could be your culprit.
check for spark and fuel - if there's no fuel then look for your main relay (fuel pump relay) and replace it.
Old Jun 7, 2008 | 07:29 AM
G2IntegraGS's Avatar
Def. check the main relay. The connections inside tend to crack and when it gets warm they wont make a good connection.
Old Jun 7, 2008 | 11:36 AM
captaindammit's Avatar
my car kind of had the same problem. turns out it was the coil in the car, its worth looking at.
Lowside
Sep 27, 2011 04:45 AM
SOHC_civic_si
36
May 21, 2008 07:31 PM
blackep925
Apr 12, 2008 04:59 PM
.ShawnD.
Aug 31, 2002 02:57 PM
No More Civic
10
Aug 27, 2002 09:35 AM
