H22A4 PROBLEMSSSS.!!!!! HELP....
Old May 26, 2008 | 08:57 PM
h22killer's Avatar
Default H22A4 PROBLEMSSSS.!!!!! HELP....
i have a 93 del sol swap h22a4 i have a stock fuel pump!! but the car it does not give in 3rd gear you think need the fuel pump like a walbro?
Old May 27, 2008 | 06:04 AM
Acidcrakker's Avatar
Default Re: H22A4 PROBLEMSSSS.!!!!! HELP.... (h22killer)
Try an FpR.
You wont need a Walboro Fuel pump for an H22.
And what do you mean by it wont give?
Old May 27, 2008 | 09:11 AM
h22killer's Avatar
Default Re: H22A4 PROBLEMSSSS.!!!!! HELP.... (Acidcrakker)
it does not have force I feel that one dies it makes pure noise but almost it does not run
Old May 27, 2008 | 09:53 AM
98vtec's Avatar
moderator emeritus
what was done to the engine prior to this happening?
you dont need an aftermarket fuel pump on a stock motor.
Old May 27, 2008 | 10:29 AM
h22killer's Avatar
Default Re: H22A4 PROBLEMSSSS.!!!!! HELP.... (98vtec)
look my car have skunk2 intake manifold,lsd tranny,clutch xtd stage3 flywheel xtd headers dc sport, but the car feel so good in 1st and 2nd gear but in 3rd gear the car does't give power, other thing my del sol has the stock exhaust you think that can be the problem???????
Old May 27, 2008 | 10:36 AM
h22killer's Avatar
the engine never open!!! stock internals
Old May 27, 2008 | 10:37 AM
98vtec's Avatar
moderator emeritus
it doesnt help. take the exhaust off and see what happens.
you arent telling us anything to be able to help you.
compression test?
cam timing?
ignition timing?
dyno chart?
what ecu?
tuning?
maintenance?
Old May 27, 2008 | 10:48 AM
h22killer's Avatar
today i do the compression test!!! all is stock I have not moved him anything what compression it must have??
Old May 27, 2008 | 10:50 AM
h22killer's Avatar
i living in mexico my friend jejje the dyno no exist here a friend said to me that it was gasoline problem, for that reason I make the commentary to expert people here my del sol has a stock fuel pump i don't need to change for other like a walbro???
Old May 27, 2008 | 12:11 PM
smackdown's Avatar
check your clutch and flywheel
Old May 27, 2008 | 12:16 PM
h22killer's Avatar
Default Re: H22A4 PROBLEMSSSS.!!!!! HELP.... (smackdown)
i will check the clutch!! but it is not slid, only that the leg of clutch this very down
DarkGriffin3156
11
Nov 21, 2021 05:33 PM
2kdrift
Jul 23, 2010 10:24 AM
no_one_
12
Apr 14, 2007 07:25 PM
nafreak
Aug 10, 2006 05:17 PM
