catch can install? need help
Old Jul 13, 2008 | 11:24 AM
Toanz's Avatar
Default catch can install? need help
Hey i've tried searching already, but have only found ways to install the catch
can on b-series motors.
does anybody on here know how to install theses on the H22, or even have
pictures on it?
THanks
Old Jul 13, 2008 | 11:25 AM
98vtec's Avatar
moderator emeritus
Default Re: catch can install? need help (Toanz)
it goes between the PCV and the intake manifold.
Old Jul 13, 2008 | 12:10 PM
NAH2B's Avatar
Default Re: catch can install? need help (98vtec)
the best way to do this would be to use two -12an hoses coming from the valvecover to the catch can w/ breather. remove the stock nipple and pcv valve from the valvecover and install two -12an bungs in the back of the cover.
i would also remover the oil baffle underneath of the valvecover as well to allow pressure to escape quicker.
ofcourse none of this will make a difference on a stock internal motor anyway except to keep crap from going back into the intake.
Old Jul 13, 2008 | 12:55 PM
saikou's Avatar
Old Jul 13, 2008 | 02:41 PM
mkazm83's Avatar
Default Re: (saikou)
^^ Air compressor filter?
Old Jul 13, 2008 | 02:46 PM
saikou's Avatar
Default Re: (mkazm83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkazm83 &raquo;</TD></TR><TR><TD CLASS="quote">^^ Air compressor filter? </TD></TR></TABLE>
Yup, cheap too for both fittings and the actual filter from Home Depot. Does the job.
Old Jul 13, 2008 | 03:02 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saikou &raquo;</TD></TR><TR><TD CLASS="quote">
Yup, cheap too for both fittings and the actual filter from Home Depot. Does the job.</TD></TR></TABLE>
How is it working out for you? Looks like the capacity is very limited.
Old Jul 13, 2008 | 03:06 PM
saikou's Avatar
That is true, it can't hold much... but I went this route because I couldn't find anywhere to mount my Greddy copy catch can. I didn't want any long hoses running around the engine bay. Have only been running this set-up for about a week and a half and there is about a spilt amount of oil in there.
Old Jul 13, 2008 | 05:13 PM
BlackCatt's Avatar
This is my setup. I kept it as close as possible to the intake manifold so i had small length lines. I used Goss fuel hose to hook it up. I also put a baffle (stainless steel wool) inside the catch can to improve its performance. In the first six months i had no baffle and collected 125ml of black crap oil. Now i have the baffle in i am going to see how much it collects in the next 6 months. My car is a dd bb2 H23a1 and so i only occassionally let her rip at full throtle. In December i will post the results of my little test. All in all very simple to install oil catch can for normal car use, if you are heavily modifying your car i would suggest some more research, i know this topic has been covered a few times by DD's and Race Drivers. Goodluck with it.
Momentum
Sep 14, 2010 09:29 PM
Powered by VTEC
Jan 26, 2008 09:03 PM
egzo04
Jun 8, 2007 09:21 PM
sikwitit
Apr 29, 2006 10:56 AM
