iacv question???
Old Jul 14, 2008 | 09:57 PM
invasian_boy's Avatar
Default iacv question???
i was wondering does your guys car still idel when you unplugg the iacv because on my 98 honda prelude when i unplug the iacv the car just dies what is causing it???
Old Jul 14, 2008 | 10:07 PM
Altilude's Avatar
Default Re: iacv question??? (invasian_boy)
it should idle without it plugged in... typically you set your idle to aprox 550+/-50 with the iacv disconnected.... with it plugged back in, it should idle higher aprox 700 +/- 50... (no load condition) perhaps your idle is set too low to maintain when the Iacv is disconnected?
Old Jul 14, 2008 | 10:08 PM
Default Re: iacv question??? (Altilude)
well i dont know my idle screw even if i turn it out all the way to get more air it still dies when i unplug the iacv??? im troubled
Old Jul 14, 2008 | 10:25 PM
vlang29's Avatar
it should still idle 700+/-50 with the iacv unplugged. Are all accessories, A/C, etc turned off when you unplug IACV?
Old Jul 15, 2008 | 12:34 PM
Default Re: iacv question??? (vlang29)
yes everything is turned off but it still dont idle
Old Jul 15, 2008 | 12:42 PM
vlang29's Avatar
so other than the idle issue, everything else is running good?
Old Jul 15, 2008 | 12:52 PM
other than idle issue everything else runs good also i have to state that sometimes the idle is so low n bad that the car just dies but there was never a time i couldnt get it to start up.
Old Jul 15, 2008 | 12:55 PM
vlang29's Avatar
have you checked ignition timing? have you done all the basic maintenance like cap, rotor, plugs, wires, fuel filter, air filter, etc?
Old Jul 15, 2008 | 12:59 PM
well my ignition timming on the 97-01 prelude are set by the ecu and cant be set, i check cap n rotor and seems good i put in new plugs, wires but not the fuel filter though
Run Away
Mar 11, 2006 05:08 PM
DC2*Integra
Sep 20, 2005 12:51 PM
