Over heating or not?
Old Jul 23, 2008 | 07:04 PM
wound tight's Avatar
Default Over heating or not?
Hey I have a 92 prelude with a H23 and I think I have a problem but not sure. The motor is feeling extremely hot no mater how I drive it, but, the temp guage shows to be normal ( I guess, its showing up to the 2nd bar). I removed the thermostat and it still gets hot just not as quick. Is this normal or do I have a problem. I was also wondering what temp the fan comes on at. The motor is stock with just a cai.
Thanks
Old Jul 23, 2008 | 07:22 PM
m00nr0ck Si's Avatar
Default Re: Over heating or not? (wound tight)
Normal operating temp is the 2nd bar or the 12 O'clock position.....Not sure on what temp the fan kicks on but I would guess around 200 or 220......
Some things to check that Ive had problems with are the (radiator cap getting wore out ,bleeding the coolant of air bubbles, bad thermostat, clogged radiator due to lack of coolant flushes)
Old Jul 23, 2008 | 07:55 PM
TruNinja619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wound tight &raquo;</TD></TR><TR><TD CLASS="quote">Hey I have a 92 prelude with a H23 and I think I have a problem but not sure. The motor is feeling extremely hot no mater how I drive it, but, the temp guage shows to be normal ( I guess, its showing up to the 2nd bar). I removed the thermostat and it still gets hot just not as quick. Is this normal or do I have a problem. I was also wondering what temp the fan comes on at. The motor is stock with just a cai.
Thanks</TD></TR></TABLE>
As long as the fans turn on, and then shut off after a few minutes or so, then you're fine. Just worry when the temp gauge gets towards the red bar fast.
meanshyguy
Aug 24, 2008 07:50 AM
poop32145432
Sep 15, 2004 03:05 PM
rdaggett
Aug 11, 2004 12:48 PM
EGhatched
Mar 14, 2004 04:17 PM
zzzkenji
Apr 23, 2003 06:06 PM
