H22A1 Engine Code and Alternaotr question
Old Jul 17, 2008 | 09:42 AM
Momentum's Avatar
Default H22A1 Engine Code and Alternaotr question
My buddy has an h22a1 vtec swapped into a 92 civic and it needs a new alternator.
2 questions... what is the engine code for the h22a1 vtec? (8th vin digit)
Also.. will an alternator from a non-vtec work on the vtec?
thanks
Old Jul 17, 2008 | 09:48 AM
vlang29's Avatar
Default Re: H22A1 Engine Code and Alternaotr question (Momentum)
the alternator will work
Old Jul 17, 2008 | 09:51 AM
Momentum's Avatar
You sure?
When i called partsource the par numbers were different...
Price of the vtec on is almost $100 more!
Old Jul 17, 2008 | 09:57 AM
Hawkze_2.3's Avatar
Default Re: (Momentum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Momentum &raquo;</TD></TR><TR><TD CLASS="quote">You sure?
Price of the vtec on is almost $100 more!</TD></TR></TABLE>
H22 has a 6-rib pulley system, while the H23 (non VTEC) has a 5-rib system, the alternator is the same. He is sure
Old Jul 17, 2008 | 10:01 AM
pentaq's Avatar
Default Re: (Hawkze_2.3)
Its not a problem to swap pulleys
Old Jul 17, 2008 | 10:07 AM
Momentum's Avatar
Ok and what year USDM prelude would the H22A1 come in?
Also why would they ahve different alternator part numbers for the 2?
Old Jul 17, 2008 | 10:09 AM
vlang29's Avatar
92-96
not positive why the different #'s, what i do know, is that i had an h23 that the alternator went out on. i took an H22A alternator, swapped the pulleys, and haven't had any problems since.
Old Jul 17, 2008 | 10:11 AM
Momentum's Avatar
Default Re: (vlang29)
So for the 92-96 preludes came two engines... H22A1 vtec and H23 non-vtec?
And alternator is the same?
ANyone have any idea what the engine code (8th vin digit) for both engines is?
I would have to take the pullay off the old alternator and put it on the new one though? How easy do they come off/stich over?
Old Jul 17, 2008 | 10:13 AM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Momentum &raquo;</TD></TR><TR><TD CLASS="quote">So for the 92-96 preludes came two engines... H22A1 vtec and H23 non-vtec?</TD></TR></TABLE>
and also F22 non-vtec SOHC
not 100%, but i believe the thing to look for is: BB1 for vtec, and BB2 for h23
Old Jul 17, 2008 | 10:18 AM
Hawkze_2.3's Avatar
I would have to take the pullay off the old alternator and put it on the new one though? How easy do they come off/stich over?</TD></TR></TABLE>
Yeah, 3 engines (F22 SOHC, H23 DOHC, H22 DOHC VTEC, Prelude S, Si and VTEC respectively).
Why are you so worried about VINs?
Yes, take the pulleys off and swap. Any auto parts store can do it minutes if you don't have the tools. Or you can just use a 5-rib belt on your H22.
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Momentum &raquo;</TD></TR><TR><TD CLASS="quote">I would have to take the pullay off the old alternator and put it on the new one though? How easy do they come off/stich over?</TD></TR></TABLE>
correct. They are very easy to change. spray the nut with some PB blaster penetrating oil, will make it even easier
Old Jul 17, 2008 | 10:19 AM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Or you can just use a 5-rib belt on your H22.</TD></TR></TABLE>
is that ok on a 6-rib A/C compressor pulley?
Old Jul 17, 2008 | 10:00 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">
is that ok on a 6-rib A/C compressor pulley?</TD></TR></TABLE>
I don't see why not?... I use a 3-rib belt with my D-series alternator with a H 5-rib crank pulley. 5 vs. 6 ribs can't be enough of a difference to cause a problem.
civicb16eg
Sep 13, 2007 10:48 PM
sony224422
Apr 7, 2007 06:10 PM
Tom123456
Jul 13, 2006 08:30 AM
wfo
Feb 25, 2005 02:21 PM
SH LUDE
Mar 28, 2003 10:07 AM
