Installing axle...
Old Jul 9, 2008 | 01:44 PM
ali.y0.'s Avatar
* B A N N E D *
Default Installing axle...
I just had my passenger side axle rebuilt. I went to install it on the car and had trouble puting it on. The reason is seems that the inner part is hitting something inside the transmission the big round part doesnt get to close to the block is it supposed to be? In other words, how close should the big round part of the inner of the axle be to the transmission?
Old Jul 9, 2008 | 01:53 PM
bb_one's Avatar
Default Re: Installing axle... (ali.y0.)
Very close, from eyeballing it, I would say around 1/16" clearance between the big shaft wall to the tranny case.
You need to get the c-clip on the axle to pop into the groove in the diff. I usually use the axle's momentum to pop it into the groove.
Old Jul 9, 2008 | 02:07 PM
ali.y0.'s Avatar
* B A N N E D *
Default Re: Installing axle... (bb_one)
Thanks for the reply. Thats what i figured. This is how it looks now...
Feel like it hitting a flat surface.
Old Jul 9, 2008 | 02:13 PM
ali.y0.'s Avatar
* B A N N E D *
It seems as if its hitting these 4 teeth looking things
This doesnt look right either. The passenger side that enter the tranny is way bigger than the driver side
Old Jul 9, 2008 | 03:11 PM
92hondalude's Avatar
thats how my DSS axles look like when they are installed. Just hold the inner part of the shaft with one hand and the other hold the outer cv and push. should make like a clunk sound when its in.
Old Jul 9, 2008 | 03:18 PM
ali.y0.'s Avatar
* B A N N E D *
Default Re: Installing axle... (92hondalude)
Im slamming the thing in there LOL and i remain with the above gap
Old Jul 9, 2008 | 05:11 PM
then its in
Old Jul 9, 2008 | 06:08 PM
bb_one's Avatar
If you have that gap as pictured, then it is NOT in.
I think I understand your situation, when they rebuilt your axle, did they use a new inner hub (the piece that has the spline to go into the tranny)? I think they may have used an incorrect inner hub which is getting stuck at the outer edge of the diff preventing the spline to go all the way into your diff.
Old Jul 9, 2008 | 06:10 PM
bb_one's Avatar
I can't remember exactly, but the half shaft spline and passenger side spline have the same hub diameter (not the spline itself, but the hub the spline is on. i think you know what I am talking about since you pointed it out in the pic)
Old Jul 9, 2008 | 08:49 PM
shutta's Avatar
if you can wait till tomorrow I have a new passenger side axle and I can measure it to make sure you have the right length. i'm too lazy to get it out of my back seat.. just too l ate. why am i even up? oh yeah, cruising honda-tech when i was supposed to be posting on craigslist. haha
Old Jul 9, 2008 | 08:52 PM
h23prelude's Avatar
in the picture the axle and splines look pretty dry, try taking some thick grease and put a thin coat on the axle splines and that area, ive had trouble getting axles to seat properly and usually a little grease helps them slide so the clip sets properly
as bb_one said, it may be a different inner hub, count the splines and perhaps try matching it to a known prelude axle.
hope this helps
Old Jul 9, 2008 | 10:40 PM
ali.y0.'s Avatar
* B A N N E D *
Thanks for the help guys. Im not sure if they did change the inner hub. I am going to drive over and have the match up with another prelude innner hub. That inner hub is hitting the 4 tooth thing DEAD ON. The way it would make sense would be that the inner hub would be the same length as te driver side one. Cause i tried the driverside on the pass side and it goes in all the way.
bb_one it would be great if you can measure it.
Thanks again everyone.
Old Jul 10, 2008 | 01:56 PM
ali.y0.'s Avatar
* B A N N E D *
Default Re: (ali.y0.)
Anyone else?
Old Jul 10, 2008 | 02:18 PM
my9thtry's Avatar
I had the exact same problem with my swap. Turns out for em it was a tiny about of slag on the smooth part of the axle shaft. When i say tiny i mean TINY. like less then .010" just enough to grab a finger nail on. I tried another axle and it went in like butta.
Good luck
Old Jul 10, 2008 | 05:15 PM
ali.y0.'s Avatar
* B A N N E D *
Default Re: (my9thtry)
I dont understand what you are saying.
Old Jul 10, 2008 | 08:04 PM
h23prelude's Avatar
"my9thtry" is saying that on the smooth part of the axle there was a tiny imperfection from maching, welding, etc... that cause the round part to have a small raised chunk of steel on it, therefore not allowing the axle in the hole
Old Jul 11, 2008 | 03:48 AM
bluedlude's Avatar
Default Re: (h23prelude)
was the spring clip reused? i swapped one from an old axle to a new axle and thats what caused some problems for me getting everything mated up. the clip was just too out of round so i had to adjust it a bunch of times before it would compress enough. the tolerances are too tight for it to be much out of round. check out the clip
Old Jul 11, 2008 | 08:41 AM
ali.y0.'s Avatar
* B A N N E D *
Default Re: (bluedlude)
it cant be the clip. The end of the inner part of the shaft does not go in at all.
Old Jul 12, 2008 | 07:11 PM
prion's Avatar
I find that many times I have to compress the axle by hand once it's lined up in the hole and smack the end with a hammer a bit to get it to pop in. Make sure you put the axle nut on the end (inverted) so you don't mess up the threads on the axle.
It should just take a little finesse, not a sledge hammer or anything. Works for me. Good luck.
redman223
Sep 7, 2011 12:15 PM
stockb18c
12
Apr 6, 2009 01:51 PM
a1320addict
Mar 10, 2006 09:53 PM
kanzdj1
Sep 19, 2003 02:45 PM
Audi RS4
Sep 10, 2003 02:04 PM
