remove abs
Old Jul 20, 2008 | 09:08 AM
GoldLudeRay's Avatar
Default remove abs
i know i seen a thread on the abs delete for a prelude equiped with abs
i know u need a f22 master cyclinder
but if anybody can find me that thread that would be great
Old Jul 20, 2008 | 09:37 AM
Apex1972's Avatar
Default Re: remove abs (GoldLudeRay)
https://honda-tech.com/zerothread?id=1347569
Old Jul 20, 2008 | 09:45 AM
Default Re: remove abs (Apex1972)
thanks simpler than i thought
i thought the brake lines were going to be
different
Old Jul 20, 2008 | 09:59 AM
Apex1972's Avatar
The front ones are different. You need new front lines, new MC and booster. Or , you can reflare the one line off of the MC that has the 12mm fitting and keep you current MC and booster. Just use some of your old lines from the ABS pump to make your short lines from the MC to the proportioning valve. Its not a real easy job with the motor in the car. IMO , I would wait until the motor needs to come out for something and do it then.
Old Jul 20, 2008 | 11:09 AM
ooo the motor's out right now
all i really need is mc/brake booster and porp valve the oem line will work right
Old Jul 20, 2008 | 01:20 PM
Apex1972's Avatar
Default Re: (GoldLudeRay)
You will need new lines to the front calipers.The rear ones will work because the prop. valve mounts right where they meet up with the little junction valve that is located under your MC. You will also need lines from the MC to the prop. valve. These will have to be fabricated. Last time I checked, the actual lines were on backorder from Honda. No word on when they would be available. Just use your leftover scrap pieces from the ABS pump to make these. You might even be able to make the passenger side caliper line if there is a long enough piece. I would at least buy the caliper lines as they are still available, you could also try ordering lines for a 94-95 LX Accord. Hurry while that motor is out of the way.
Old Jul 20, 2008 | 02:02 PM
92hondalude's Avatar
Default Re: (Apex1972)
those picture anrt working and the website isnt working..
Old Jul 20, 2008 | 04:29 PM
kornerk12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 &raquo;</TD></TR><TR><TD CLASS="quote">The front ones are different. You need new front lines, new MC and booster. Or , you can reflare the one line off of the MC that has the 12mm fitting and keep you current MC and booster. Just use some of your old lines from the ABS pump to make your short lines from the MC to the proportioning valve. Its not a real easy job with the motor in the car. IMO , I would wait until the motor needs to come out for something and do it then. </TD></TR></TABLE>
Do you need a new master cylinder and booster ? Why can you not use the old one ?
Old Jul 20, 2008 | 06:02 PM
Apex1972's Avatar
Default Re: remove abs (kornerk12)
On the ABS MC, one of the fitting is a different size. On the non ABS, they are both teh same. You can use the old one, that is what I am gonna do on mine, but you have to reuse the large 12mm fitting and reflare a line to go to the MC. That way you do not have to replace the booster and MC which is alot more work. Just make sure you keep all of the metric fittings as you remove all the components and keep track of where the 12mm one goes, I think it is the one on the MC closest to the firewall.
supersilverdc2
Mar 30, 2015 11:35 AM
NotoriousJJE
Feb 16, 2012 10:41 AM
sh4mr0ck
Jul 23, 2009 07:21 AM
ls19integra95
Dec 2, 2007 03:52 PM
