Sound while driving
Old Jul 13, 2008 | 02:16 PM
kornerk12's Avatar
Default Sound while driving
My car sat for about 3 months without being moved. While it sat there I had new front wheel bearings pressed in. Now that the car is driving I hear what sounds like rust on the rotors rubbing. But this is constant even after driving for 45 mins, so I doubt it rust. The sound is only while in motion. Im thinking either the splash guards are rubbing or it could be the rear wheel bearings ?
Old Jul 13, 2008 | 02:58 PM
98vtec's Avatar
moderator emeritus
Default Re: Sound while driving (kornerk12)
inspect the dust shields
Old Jul 13, 2008 | 03:29 PM
kornerk12's Avatar
Default Re: Sound while driving (98vtec)
thanks i will do that. However what are the normal sounds and symptoms associated with bad wheel bearings ?
Old Jul 13, 2008 | 03:48 PM
mattsnooz's Avatar
screetching sound usually. You hear them all the time once they are shot. I would take tires off. Do a visual inspection. Spin each tire and listen to which one is making the noise. Not a hard problem to isolate.
Old Jul 13, 2008 | 03:55 PM
kornerk12's Avatar
Default Re: Sound while driving (mattsnooz)
so there wont necessarily be free play then ? Is there anyway to look at the bearing itself to say if its bad or not ?
Old Jul 13, 2008 | 04:15 PM
Saosinx's Avatar
bad bearings will show play all around. but to isolate it as being a bearing, check 12-6.
pho iz good
Feb 27, 2005 12:35 PM
PAID-$$$
Jun 30, 2004 09:12 AM
Nice_Dc2r
Aug 21, 2003 01:11 PM
user 9782082308
Jan 26, 2003 01:04 PM
Greyout
Dec 7, 2001 10:44 AM
