Electrical Problem? HELP!
Old Jul 8, 2008 | 02:10 PM
paulwithap's Avatar
Default Electrical Problem? HELP!
Alright, so here's the deal:
I have a 1994 Honda Prelude, manual, with a jdm h22a. Recently, while on the highway, I noticed my tach needle starting to bounce up and down a bit. Other times, there would be no bouncing at all. Over the next week, the problem started to get worse and worse, and eventually the car would start to stall out when in neutral. It would start back up right away at first, but that got worse too, until one night, the car would not start at all, even with giving it some gas (which had helped other times). Now, the car will start up right away and act fine at times, but it seems like as the engine starts to warm up, the problems get worse. I'm also experiencing jolting and hesitation at times. I had the car at a shop for about a week, and they could not figure out the problem. The vacuum lines are all good, I know, and the car idles normally. If anyone has any idea what the problem could be, please let me know.
Side note: I did replace the distributor about a month and a half ago after going through a large puddle, but it worked fine for a month until this started happening.
Old Jul 8, 2008 | 08:30 PM
paulwithap's Avatar
Default Re: Electrical Problem? HELP! (paulwithap)
bump
Old Jul 9, 2008 | 06:46 AM
Jagan'92's Avatar
maybe some of these will get you started:
https://honda-tech.com/zerothread?id=1852496
Old Jul 10, 2008 | 02:04 PM
paulwithap's Avatar
thanks, but no help there. 3 shops have looked at it so far, still no answers. taking it to king motorsports tonight. hopefully they can help.
Old Jul 10, 2008 | 02:21 PM
Acidcrakker's Avatar
so all your problems started happening after you drove through the large puddle?
You dizzy controls the RPM gauge. Check your coil out too!
Old Aug 8, 2009 | 12:46 PM
paulwithap's Avatar
hahaha acidcrakker. i remember you from myspace, getting flamed constantly back in the day.
turned out to be my alarm system.
Cphobia
Honda Civic (2006 - 2015)
Mar 31, 2017 05:28 PM
EphoraL
Classic Hondas
Jan 12, 2013 12:02 PM
GSR15
Aug 12, 2007 12:39 AM
BigD+Itsuki
Jun 21, 2002 11:40 AM
